error P0A0D after rebuild.. saftey plug seated correctly, other codes present
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Beachbummm, Mar 29, 2018.
  1. JC91006
    16,936
    8,647
    I'm curious how long this will last you. As you stated before, your previous repairs have lasted a long time. But now with older modules.....time will tell.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Doesn’t seem like (or nothing noted) any balancing was done, just a swap and go:(.
    It will be interesting (y).
    JC91006 likes this.
  3. JC91006
    16,936
    8,647
    Yeah BeachBuum is a swap and goer
  4. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    ya gotta do what ya gotta do.. voltages ranged from 7.4 to 7.9 so it should be fine.. as mentioned all gen 2 mods are nearing 10 years old as is the car so I think the next time it dies Ill just sell her as-is and get something else.. its not cost effective to put over $1000 into a car wirth $2500 in good condition.. yes I know KKB says my baby is worth $3800 but in the real world its $2500 on a good day, cash buyer are few and far between here
  5. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Thankyou Pat.
  6. Andyprius1
    2,327
    859
    Cool CA
    TY that all makes sense.
  7. Beachbummm
    1,160
    393
    true I got 14 months out of the last one for a 2 mod swap... I assume the car is still driving around somewhere sold it when I bought this 08.. its just a car, they all die sooner or later.. that's why I don't pay a lot for them to start with..
  8. scargi01
    scargi01 Active Member
    785
    58
    Missouri
    I experienced this very code on my 05. I replaced modules and put in back in the car, connected it up to see if it would throw any codes. I turned the car on and had no issues so I decided to drive it around a little. On the way back I had to make a hard brake because of traffic. Almost immediately it threw codes and the red triangle. When I got back home and researched it I found that not being grounded could be a cause of the problem. I bolted the case down and the issue went away. I guess when it put it in the car and connected everything it was grounded but the hard braking maybe moved it a little and it lost ground.
