Error P3221/315 GENERATOR INVERTER TEMPERATURE SENSOR CIRCUIT RANGE/PERFORMANCE
Discussion in 'Gen 2 Prius Technical Discussion' started by chiciuc, Jul 26, 2018.
  1. chiciuc
    chiciuc Junior Member
    Romania
    I have error P3221/315 GENERATOR INVERTER TEMPERATURE SENSOR CIRCUIT RANGE/PERFORMANCE on Prius 2 (2006) EU.
    I already checked
    - inverter coolant level - ok
    - auxiliary battery voltage - ok
    - inverter water pump - ok
    I noticed the big difference of inverter temp MG1 (97 oC) and inverter temp MG2 (44 oC). Something is wrong
    Any advice?
  2. chiciuc
    Romania
    thanks. I will check.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    The inverter pump may be working but poorly. Should look like the fluid is boiling when you look at reservoir in ready. If it’s just barely moving that’s an issue in this heat.
    If you Have never changed the inverter coolant or trans fluid
    Now is the time.
    Given how important the inverter coolant pump is if I saw any dtcs like your seeing I would change it ASAP.
    Since your in Romania your car may never have been serviced by the pump tsb recall years ago.
    New pump
    New coolant.
    New trans fluid.
    chiciuc likes this.
  4. chiciuc
    Romania
    thanks. I will change.
  5. chiciuc
    Romania
    More infos:
    - temps drops on Inverter MG1 when I running all-electric or braking.
    - temps raise when accelerating (ICE + MG2) and I heard a noise under hood (like a hole in exaust).
  6. edthefox5
    10,096
    4,840
    Clearwater, Florida
    How old is the inverter coolant?
  7. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Did you make it up to step 10 on page 4 (out of 5) on the above PDF?
    What have you discovered by working through the linked diagnostics for DTC 3122?
    Raytheeagle likes this.
  8. chiciuc
    Romania
    I didn't tested pas 9 and 10, yet. Do you think higher temps on inverter MG1 is from poor connections?
  9. chiciuc
    Romania
    I don't know. Car has 190.000km on odometer, until 2013 was in Belgium.
  10. chiciuc
    Romania
    More infos:
    - the temp drops on Inverter MG1 when I running all-electric (eg: from 90oC to 60oC)
    - the temp drops a little or remains steady when braking.
    - the temp raise when ICE charge battery
    Seems Inverter MG1 get hot when charging battery.
    PS: I have also a hole in exhaust.
  11. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    As a point of reference, my MG1 averages about 20c hotter also.
    chiciuc likes this.
  12. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Stop analyzing and start wrenching.
    chiciuc likes this.
  13. chiciuc
    Romania
    I did some logs with techstream. Can take a look?
    • tse.zip
      File size:
      24 KB
  14. edthefox5
    10,096
    4,840
    Clearwater, Florida
  15. chiciuc
    Romania
    - I changed the pump (inverter) and I ventilated the cooling system.
    - I opened the inverter, checked the connections including those from MG1 and MG2. all good
    Same problem.
  16. chiciuc
    Romania
    I replaced the inverter with a used one
  17. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    A year later I see. Did it help your problem?
