ethanol issues
Discussion in 'Newbie Forum' started by dmjatl, Jun 13, 2013.
  1. dmjatl
    dmjatl New Member
    I'm new to this forum. My mileage had been going down; and about a week ago, my check engine light came on. I took the car to get serviced at my Toyota dealer and was told that my gas had too much ethanol in it. I almost always use the gas at Sam's club. I haven't driven enough to need to refill yet, and my milage is continuing to go down. The engine also revs before it goes off at a red light and yesterday, at times, would not even go off when I stopped. Can anyone tell me if there is a particular station whose gas helps resolve this problem?
    Thanks.
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Welcome aboard. I'd be curious to know what state you are in. This is an unusual diagnosis. 10% ethanol is pretty much standard, and hard to believe you could get more than this. But there is such thing as Top Tier gasoline. Here you are talking major brands that meet certain standards: your Shells, Chevrons, Exxons, BP etc. You can google Top Tier gasoline to find the details. Some states may offer 15% ethanol and 85% ethanol, so check your pump to see what you are getting. Some states you can get 0% ethanol, but your car does not need it. Most of us use the standard 10% ethanol with no probs.
  3. richard schumacher
    7,683
    1,066
    United States
    I believe wj meant to write, "but your car does NOT need it". E10 is fine for a Prius, but *don't* use E85.
    Drive it for another tankful and see what happens. If you continue to perceive a problem take it to a different Toyota dealer.
  4. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Ethanol is a good solvent in cleaning the injectors. In a conventional gas tank, condensation can build up when outside temps drop. This condensation gets absorbed by the ethanol and sent to be burned in the engine. The Prius doesn't have the condensation problem due to the fuel bladder.
    If the E10 is left in the tank for months, then you run the risk of the fuel breaking down in the fuel system. Fuel today just does not last like fuels in the past.
    DBCassidy
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    OP has a Gen III, no bladder
    WE0H likes this.
  6. ETC(SS)
    7,514
    Greetings and Welcome Aboard!
    Unless you put E85 in your car....and I don't think that this is the case, since I've never seen a Sam's that sells E85.....your Toyota dealership juuuuuuust might be full of crap.
    Did they pull a code?
    What was it?
    How did they test your gas for overethanolization and how much ethanol did their "test" tell them that your fuel contains?
    Get another opinion.
    You have two problems....or maybe just one.
    Many things can cause a Prius' fuel efficiency to drop but there is a specific reason that your CEL is illuminating.
    If you're trying to burn E-85....or some designer blend of E85 and E10....stop....otherwise, you're going to have to live with both the idiot light AND the diminished fuel efficiency.
    More info would be helpful to determine what your problem might be and somewhere in these hallowed halls there is a looooooong questionnaire concerning "why is my fuel efficiency dropping?"
    Good Luck!
  7. WE0H
    WE0H Senior Member
    3,247
    528
    The OP started two identical threads on this topic :confused:
    Mike
    Mobile on my SGH-i717
  8. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    I doubt Sams E10 is the problem, as I have used it in my Prius without problems or measurable MPG drop.
    I have run as much as E30 In my gen 3 Prius without any drivability problems or any warning lights .
    If you suspect your fuel supplier is selling gasoline advertised as ethanol free or if you suspect the ethanol content is higher than the 10% stated on the pump, Your local Briggs & Stratton dealer sells an easy to use fuel test kit for about $11. I have this kit, and it works well to detect if any ethanol in fuel and the % of ethanol used.
    795161 Alcohol Tester
    WE0H likes this.
  9. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Thank you Richard...you are correct. Made the edit. That's funny I fixed that post a couple days ago (I tried anyway). Oh well, we are missing the OP report back.
  10. Hill Billy
    Hill Billy New Member
    I have just bought a 2012 Gen III Prius, and the manual recommends premium unleaded (>=95), but the label on the fuel cap says "Ethanol E10 suitable." E10 is 10c/l cheaper than 91 normal unleaded, and Premium is 10c/l more than normal. So that means that there's a huge economic incentive to using E10. If so, why's there no mention of this in the manual? Is E10 91 or 95 octane, or doesn't it matter? If it doesn't matter why not just use normal 91 unleaded?
  11. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    Really? The 2012 manual recommends premium unleaded? My 2010 uses 87 octane regular. Did Toyota really change the gas requirements?
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No. Neither of mine did.
  13. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Octane is measured differently around the world, if he is not in the USA, he may be using Research Octane, Motor Octane or, as in the US, AKI Octane as a standard.
    Octane rating - Wikipedia, the free encyclopedia
    The US 2012 Prius manual calls for 87 AKI Octane, or 91 Research Octane. (Page 3 of this PDF or page 562 of the manual)
    http://www.toyota.com/t3Portal/document/om/OM47704U/pdf/sec_06-01.pdf
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    [Duplicate post]
  15. RRxing
    2,562
    1,839
    NEPA
    2010 manual reads the same.
    OP did not give a location, so I assumed USA. You are correct in pointing out the non-standardized octane ratings.
    Edit - I just noticed the OP posted pricing as c/l (per litre), so it's non-USA.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If I was magically able to make a single change to PriusChat, Location would be a mandatory field.
    WE0H, RRxing, john1701a and 1 other person like this.
  17. El Dobro
    El Dobro A Member
    7,102
    3,282
    It sure would help with a lot of things.
  18. thymara
    thymara Junior Member
    59
    Edmonton, Alberta
    2020 Prius Prime
    *deleted*
  19. thymara
    59
    Edmonton, Alberta
    2020 Prius Prime
    clearly a delete option for edit is required
    I apologize for my incompetence
    WE0H likes this.
  20. Hill Billy
    Yes it's very clearly stated in the manual. Maybe it's different in Australia. The model number is ZVW30R.
