EU availability and reviews?
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jan 4, 2017.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Solar roof on any of the Japan trims?
  2. Tideland Prius
    16,681
    Optional on S and S Navi Package
    giora likes this.
  3. Tideland Prius
    16,681
    S = standard
    O = optional
    - = not applicable
    You think Toyota has some weird combinations in your country, check out *1 lol.
    Options A Premium A w/ Leather A S Navi Package S
    2 Charging Cable AC100V - AC200V (15m) O O O O O
    3 CHADEMO outlet S S S S O
    4 Solar Charging System - - - O O
    5 P215/45R17 Wheel & Tire Pkg O*1 O*1 O - -
    6 LED Front Fog Lamps w/ Accessory Lamp S S S S O
    7 ITS Connect (V2I) O O O O O
    8 JBL Premium Audio O*1 O*1 O
    9 Navi-Ready Unit w/ backup camera*2 - - - - O
    10 ETC 2.0 (electronic toll)*3 O O O O -
    11 Accessory Outlet (AC100V - 1500W/Vehicle Power Connector)*4 S O O O O
    12 Wireless Phone Charger*5 O O O - -
    13 Cold Weather Specification (Windshield Deicer LED Rear Fog Lamps)*6 O O O O*7 O*7
    *1: 215/45R17 tires & 17 x 7J aluminium wheels with centre ornament and JBL Premium sound system cannot be installed at the same time
    *2 It becomes operable when a dealer-installed navigation unit is installed. Cannot use in conjunction with a backlit licence/number plate
    *3 Separate setup fee required. See dealer for details
    *4 Please use electric items that use less than 1500W total. Some products that use less than 1500W may not work with this outlet. It does not indicate a malfunction.
    *5 If you are wearing medical electrical equipment such as implantable cardiac pacemakers, please consult your doctor before using wireless charging. It is known that the charging operation affects medical electrical equipment. You can also stop the charging function, so please contact your dealer for details.
    *6 Consider this option for use in cold climates. Cold climate specification is mainly aimed at improving the reliability and durability of wipers and the like. In Hokkaido area, cold climate specification is standard equipment on all models.
    *7 Heated door mirrors are included with the cold climate specification.
    giora likes this.
  4. Heikki Finland
    Finland
    Excel
    Yea the trims in Finland are similar the executive trim is a add on..costs 4000 EUR, but you can not buy executive trim and solar roof in Germany either..I wonder what was the reasoning?
  5. alpilotx
    alpilotx New Member
    Germany
    As far as I understood (at least this was the leading theory in the German forum) its mostly because of weigth concerns (the solar variant adds the weight of the solar roof and - as far as i understood - an additional buffer battery). So, to compensate this "extra weight" they removed the other features.
  6. bwilson4web
    16,540
    Huh? Would have thought the car came with a portable EVSE charging cable. Is this 'optional' like selling a car with optional tires? <grins>
  7. Prodigyplace
    12,716
    11,849
    Central Virginia
    You get tires but need to supply your own air:D
    bwilson4web likes this.
  8. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I think both of you are describing the same animal:)
  9. Tideland Prius
    16,681
    I understand that to be a conversion cable from 200V to 100V.
