Euro model's AHS Adaptive high beam system
Discussion in 'Prime Main Forum (2017-2022)' started by GT4Prius, Apr 19, 2017.
  1. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I agree that the optical speed limit sign recognition is inefficient and prone to spurious false indications. A Mickey mouse system for idealised roads that don't exist.
    From various threads regarding some chips, etc. I think the screen glass may be too thin for rain detection. At least until someone who understands these matters come along and puts me straight!;)
    unicorn likes this.
  2. unicorn
    unicorn Member
    48
    EU
    :LOL: btw., it is not offered in US (for Prime)
  3. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    I don't believe the new AHB-System on Prius PHV will use the same camera as the regular Prius,as it has to check on upcoming cars as also on cars ahead keeping them constantly in the shadow and not dazzling them while the rest of the road can be still lit up with high beam,so maybe,with a better camera,also the RSA will perform better !?
  4. davidtm
    davidtm Member
    180
    TJ'ville
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I've heard others state that in USA the speed limits are embeded in the satnav data.
  6. civicdriver06
    797
    324
    Germany
    Yes and they are in Europe too,but the saftey sense camera on European Prius/Prime can also read the speed limits as the car passes them,sometimes leading to a confusing situation as road map data and the poor reading capability of the camera show two different speed limits...
  7. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    I do wonder why some people seem to enjoy rubbishing the Prius when they own one. There are plenty of people quueing up to rubbish Toyota and the Prius, mostly out of prejudice and ignorance.
    Prejudice ignorance and unconstructive negative criticism are things that most of the time Prius owners and Priuschat seem mercifully free of. Most of the time.
    Packitt has also posted much of this already in a different thread.
    RSA is not perfect, but most of the time it works well for me on the roads on which I drive. I have some suggestions for Toyota as to how it might be tuned to work better with fewer false indications, which I intend to pass on to them. I don't think that calling it Mickey Mouse is justified. It is better than that IMHO.
    They rain sensing wipers on my Excel model also work great. No problems at all.
    AHB headlights on the Gen4 are completely different, with completely different lamp design and also beams that are too high can be adjusted.
    If we can now leave all that aside and get back on topic, what I have discovered on further investigation is as follows.
    The AHS headlights on my Euro PHV work really well as I have said but with the oddity about 40 mph.
    What I can say with confidence now is
    1. Unless I am traveling at or above 40 mph, when I first turn the headlights to main beam, nothing happens. It makes no difference. AHS and main beams stay off.
    2. Once I reach 40 mph,the AHS system activates and stays active below 40 mph until I travel through an area with street lighting, when AHS turns off and stays off until I reach 40 mph again.
    3. Low speed speed around 30 mph does NOT cancel AHS contrary to what I first thought.
    4. Manual switching is NOT a practical option as I said. In order to switch main beams to manual it is necessary to use a switch that is below the charge timer switch, and therefore so out of view and ready reach that it is not safe to use while driving, only when stationary.
    Having said all that this it's not a deal breaker. The lights work well, but I would like to understand this difference between what the Manual says and what I experience.
    RCO and Tideland Prius like this.
  8. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Amazing technology, I hope it eventually makes it to the U.S. Watching the French video you can see when there is oncoming traffic it selectively darkens just the area ahead and to the left while keeping other directions fully lit.
    However it also seems overly sensitive to oncoming traffic far in the distance. Although I am basing this on just one observation in the French video
    It's on a part of the video in a straight stretch of road, seemingly in the country away from any street lights. At 3:33 an oncoming car passes by, and as expected after the car passes it immediately resumes illuminating the area ahead and to the left (which I will call AL for brevity). In the far distance you can see the dot of an oncoming vehicle. But then at 3:40 it darkens AL even though the oncoming car still seems far away. A 3:59 the oncoming car dips below the horizon and AL is illuminated again (ignore what appears to be the car coming back up at 4:02 as that turns out to be just a street sign). A 4:22 the oncoming car, much closer now, pops up over the horizon and AL immediately darkens as it should. The oncoming car passes by at 4:31.
    But that means it stopped illuminating AL at 3:40 because of a car that was 50 seconds away! I can't gauge the exact speed they are travelling but I am guessing the oncoming car was almost a mile away at that point. The law says you should dim your headlights for any oncoming vehicles within 500 feet (1/10th mile). For courtesy I usually dim sooner than that, but not a mile!
    I realize I am basing this on watching a video, and I could be misinterpreting, but the question is how well does it gauge the distance of oncoming traffic? Is the sensitivity adjustable? In case it dims too early, I guess you can just flick the brights on, but then does it fight with you and keep turning them off?
    Not trying to bash, just trying to get a feel for how well it works, and how easy is it to override temporarily when needed. Sort of like cruise control, one click and you can disengage, another click to resume. Is it the same with AHS?
    Tideland Prius likes this.
  9. Tideland Prius
    16,681
    Probably the same as us - just press the AUTO (high beam) button to the left of the steering wheel to turn off the AHB (since your headlight stalk is already in the high beam position, it'll turn on your high beams). Press the AHB button again to re-engage AHB.
    RCO likes this.
  10. unicorn
    unicorn Member
    48
    EU
    I would say, regarding to the AHS sensitivity settings we can rely only on practical experiences ... fortunately, GT4Prius/RCO are very satisfied.
    For example, here is another video (US LEDs) with better FHD quality, not moving, and an author can see 15 trees against about seven trees in video:
    According to my personal experience the oncoming high beam can be distracting from a long distance. Moreover, take into consideration 27 countries in EU with the different regulations :notworthy: :)
    giora and RCO like this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Please don't think I'm rubbishing the Prius, I most certainly am not! The regular inaccuracies of the sign recognition is a nuisance at times, so I wish there was some way of turning it off.
    For example, I'm driving along a UK dual carriageway with speed limit of 70mph when the camera sees a speed sign to the left on another road of 40mph and thereafter fails to correct back to 70 again. Same thing with truck limit signs and billboards, too many errors creep in to dilute the overall efficiency of the system. I still think the Prius is great, but to have an incorrect speed warning on the HUD replace the power gradient graph is a bl**day nuisance and that is my personal opinion. YMMV.
  12. unicorn
    unicorn Member
    48
    EU
    I agree that if AHS will by algorithm decide to turn off high beam (and actually you need high beam), then it takes a time to find the switch to turn off AHS and maintain high beam. So, it could be arranged a faster way. On the other hand, to avoid a dazzling effect with AHS on is very practical and fast, just to push/pull a lever.
    Generally, AHS is a big step in night driving safety. I've checked the IIHS crash test results for Prius Prime: 2017 Toyota Prius Prime
    See Headlights section, low beam left side is approximately four times shorter as high beam left side. Following, AHS can provide up to four times (!) better visibility of the left side and up to two times better visibility of the right side.
    GT4Prius and Since2002 like this.
  13. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    Maybe your dash is different but as I said IMHO the button position on my car to switch headlights to manual is not suitable for using when driving.
  14. Tideland Prius
    16,681
    No it's the same as ours. It is a little out of the way, I agree.
  15. civicdriver06
    797
    324
    Germany
    But that cannot be the solution!
    It should be no problem at all for Toyota to update the systems software,but if people just turn off the RSA instead of complaining that's not likely to happen !
  16. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    Complaining IMHO isn't helpful, it's also too easy and far too popular!
    Constructive suggestions for improvement are what will help and as I have said I will make mine direct to Toyota.
    If it was no problem at all to update the car's software I suspect Toyota would have done it. But if, as I have, you have suggestions as to how in practical terms they can give the car more intelligence to distinguish between signs it should recognise and those it should ignore, please do tell them. But this is not an easy task in pattern recognition software IMHO.
    Also, as I have said, there are aspects of the car that work better in some situations than in others. Lane departure is one, RSA is another IMHO.
    So it IS part of the answer for those who find it helpful to use it in places where it works for them and those who don't or in places where it works less well, to turn it off.
