European Intro of 2023 Toyota Corolla Cross Hybrid gives Hints for US Model
Discussion in 'Toyota Hybrids and EVs' started by drash, Oct 21, 2022.
  1. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    The all-new Corolla Cross
    The European version, known as simply Toyota Corolla Cross, delivers both a 1.8L and 2.0L Hybrid system. Only Turkey and Israel are getting the 1.8L Hybrid system which is front wheel drive (FWD) only. The 2.0L comes in both FWD and AWD-i for Europe, however, the North American version will stick with the 2.0L AWD-i so we'll concentrate on like specs for that.
    The Corolla Cross Hybrid has the following specifications:
    2.0L engine puts out 112kW (150hp) and 190NM (140lb-ft)
    Battery is a .9 kWh Li-Ion (60 cells 4.08 A/hr capacity)
    Front Motor is a 83kW (111hp) and 206NM (152lb-ft)
    Rear Motor is a 30kW (40hp) and 84NM (62lb-ft)
    WLTP fuel consumption is 5.3L/100km (44mpg) to 5.6L/100km (42mpg) combined
    0 - 100km/h in 7.5 seconds
    We already know a lot about the NA Toyota Corolla Cross Hybrid except for official EPA specs. Overall system power is 145kW (194hp). I'm guessing the EPA will be about 39 - 40 mpg combine EPA, somewhere in the neighborhood of the Venza. Price on the gas only Corolla Cross LE AWD is $26,095 so again I'll guess about $28,100 for the Toyota Corolla Cross Hybrid LE. Nothing on the Toyota Canada site yet. Curiously Toyota Canada lists the 0 - 100km/h as 8.2 seconds and US lists it as 8.0 seconds to 0 - 60 mph. I'll let the one liners commence from here. :cool:;)
  2. Trollbait
    11,560
    Well, 100km is 62.14miles. Maybe the Europeans get better tires, or a lower weight base trim.
    "...fifth generation self-charging hybrid electric system...":rolleyes:
  3. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    Oh yeah curb weight is listed as 1505kg (3,318lb) so about the 219kg (482lbs) less than a RAV4 Hybrid. It's also about 15kg (33lbs) more than a gas only 2022 Corolla Cross AWD. Toyota Canada and USA have been using pre-production models so maybe the Europeans posted on a production model.
