European "Prime" has different EV mode names
Discussion in 'Prime Technical Discussion' started by GT4Prius, Feb 26, 2017.
  1. WimN
    WimN Junior Member
    37
    36
    Netherlands
    The order was from begin juli 2016!!!!! It should have been delivered in December 2016.....
  2. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
  3. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    I can't believe that EU EV City mode doesn't use both el. motors, I hope @WimN can somehow test this and report back.
  4. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Well, it was already confirmed by Toyota:
    EV-city mode – Provides a greater restriction on engine intervention and therefore uses the electric motors only, for up to 53 kW. This was designed to suit usage within stricter European city emission zones. The engine will only be activated if you kick down the throttle fully.
    European "Prime" has different EV mode names | Page 3 | PriusChat
    If it is restricted for up to 53 kW there in no need for dual motors.
    Engine joints only by the kick-down switch (full throttle).
  5. WimN
    WimN Junior Member
    37
    36
    Netherlands
    No idea how to test that, my guess would be that the 'throttle' is just limited to 53KW and that the computers decide how to supply that power. Anybody an idea how to test that??
  6. Trollbait
    12,830
    A Scangauge should be able to report if MG1 is spinning in anyway.
  7. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    Acceleration test in EV city and EV mode without engine turning on? I have no idea how hard will be to press the accelerator pedal just right (for engine not to turn on).
  8. WimN
    WimN Junior Member
    37
    36
    Netherlands
    Sorry. no Scangauge available. Also don't know if the Scangauge supports all codes for the Prius PHV (Prime).
  9. Trollbait
    12,830
    You would have to use Xgauge function to program in some readings.
    Perhaps a phone app will give them.
