EV Doesn't kick in with a full charge
Discussion in 'Prime Fuel Economy & EV Range' started by LAP, Nov 7, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Ok, I will see you your after dark and 22F with my after dark and 40 F. Drove round trip there and back all EV
    51,839
    what page is that? page 126 is something different.
  3. priuscatprimeguy
    2,730
    2,640
    The only the manual states is that if the battery temperature is below freezing, the traction battery heater will bring it back up to freezing. Note that it's battery temperature... so the car will probably have to sit outside for almost a day (assuming you used the car earlier) before the battery temperature drops below freezing. (I think for the Gen 4 had something similar where Toyota suggests that it might take a few days of sitting outside below -30°C before the battery temperature drops below -30°C and the Li-Ion models will require that the battery warm up above -30°C before the car can be driven).
    And in addition I thought freezing was at 0 degrees C not -30 degrees C:confused:
    51,839
    can you find the page? page 126 states what i quoted in the 'ev range in cold weather' thread.
  5. Tideland Prius
    16,547
    It's not in the manual.
    You know, sometimes I say things over and over and I originally give the source and then I forget where I found it because I assume everyone's read the initial post? Luckily, this isn't one of those times. I found my source.
    -30°C is Gen 4 with Li-Ion
    Arctic_White, bisco and Prodigyplace like this.
  6. priuscatprimeguy
    2,730
    2,640
    Prodigyplace and Tideland Prius like this.
  7. bisco
    51,839
    thanks t/l, what is the source of the information?
    priuscatprimeguy likes this.
  8. Tideland Prius
    16,547
    It was on page 15.
    Arctic_White and Prodigyplace like this.
  9. bisco
    51,839
    thanks, i wonder if they changed that. and if not, how does it jive with what is printed on page 126 of the manual.
  10. Tideland Prius
    16,547
    Page 126 in the manual doesn't specify temperature. It only generalizes and states "low temperature".
  11. bisco
    51,839
    exactly. why do you think?
  12. Tideland Prius
    16,547
    Cause the typical owner doesn't need to know? It's only ppl like us that want to know the nitty gritty details.
    westy72658 and priuscatprimeguy like this.
  13. bisco
    51,839
    the typical owner doesn't read a 700 page owners manual.
    your post basically makes the heater useless.
    the manual makes it sound like the battery warmer will help forestall engine running, or perhaps increase ev miles.
  14. priuscatprimeguy
    2,730
    2,640
    now THAT's delusional thinking:p
  15. Tideland Prius
    16,547
    So they'll never know about the traction battery heater lol.
  16. bisco
    51,839
    what traction battery heater?(n)
  17. priuscatprimeguy
    2,730
    2,640
    yup, missing from the PIP:cry:
  18. bisco
    51,839
  19. bisco
    51,839
    on the plus side, i'm not losing any sleep, wondering if i have one, or what it does.:)
  20. priuscatprimeguy
    2,730
    2,640
    yup, it's a mystery:confused:
