EV experiences
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by john1701a, Feb 21, 2013.
  1. ntucker
    ntucker Junior Member
    30
    Yep. What else did you think I meant by "efficiency just isn't conducive to generating waste heat, I guess"?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    The EV experience part is discovering when the heater still runs after the engine has stopped, how long that coolant will continue providing warmth.
    You end up blocking the grille to help with heat retention and get an aftermarket gauge to monitor temperature.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    My wife and I are fine with the heated electric seats. We don't bother using the inefficient cabin air heater, unless the windows fog up, due to inability (rain,etc) to open window.
    I found it widely depends on the speed I am driving with the engine on. At highway speed, the cabin heater comes on very fast. In slow city driving, the engine is rarely running and when it does, at low load so the cabin heater is slow. Warming up the engine takes gasoline the size of two eggs. You won't get much heat from that amount of gas. :)
  4. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    As for my EV experience, I am very satisfied with the PiP. PiP is covering my frequent short trips in EV mode. EV power is more than enough for acceleration and keeping up with traffic in NYC.
    I charge every other day (in weekdays) because my daily driving is so short and I want to keep the SOC low to extend the battery life.
    It is more efficient than my old 2006 Prius in HV gas mode. The gas engine revs lower, so it is quieter as well.
    I did a valet parking last weekend. While waiting to get my PiP back, I'll hear gas engine revving before cars coming out around the corner. These guys drive pretty hard because there was a long line waiting. My wife and I could tell the upcoming car isn't ours because we heard the gas engine. When my PiP came out, it was silence (just the noise maker barely) and the valet driver did not trigger the gas engine.
  5. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Yeah, it has a conventional heat exchanger that uses engine coolant to heat air as it passes over it's radiator fins. Same as most water cooled ICE cars.
    Point is- my 2003 CR-V gets toasty warm in the first few min of driving, even with the PIP's ICE running as soon as I pull out of my driveway on cold mornings- the heat is very slow to come up. The car I had before that- Nissan Pathfinder had average cabin heat, our Jeep Cherokee had adequate heat as does our Expedition. Now that I've gone thru Dec, Jan and Feb with the PIP- I'd rate it's cabin heat as poor. Same with it's front windshield defroster- compared with my other late 90's and later built cars- it's sub-par.
  6. john1701a
    12,840
    5,311
    58
    That's what the HV/EV button is for.
    Using EV-BOOST mode (in EV, but the engine running for heat) will limit the amount of heat available.
    It's easy to confirm too. Push the button and watch what happens to the engine RPM. It switches from low to high, resulting in coolant temperature rise.
    Unfortunately, spreading the word about difference that makes has been a challenge... since it took us awhile to make the observations in the first place. We also discovered that the temperature setting for the heater itself directly affects when the engine runs. The higher the setting, the higher the coolant threshold. That's different from the way the regular Prius operates, which uses a non-changing threshold instead.
  7. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . When they first came out with the Datsun, the designers could not understand why Americans could not bring thier battery inside the house overnight to eliminate Winter battery problems. Kind of interesting.
  8. Andyprius1
    2,327
    859
    Cool CA
    My other car, actualy the wife's, starts blowing warm air before I get to the end of the court. A very short block. It's incredible! A Honda Civic.
  9. Andyprius1
    2,327
    859
    Cool CA
    It is pathetic, in fact the whole HVAC is pathetic as was Gen II, but I suppose Toyotas aim was high mpgs and this is the way they did it. So I will live with it and be happy with my high MPGs. Last trip was 1400 miles at an average of 93 MPG.
  10. ny_rob
    1,968
    813
    L.I.- NY
    Minor inconveniences aside- it was an excellent 1/2 ton small pickup- the beginning of a legend.
  11. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I wonder how the Volt and Leaf handle the cold. Maybe some owners could report in. I know it is probably blasphemy...but even in a pure EV it might make sense to have a tiny gas tank or tiny propane tank to use for heat in extremely cold. A solution might be one of those small propane tanks used for soldering pipes. It would be interesting to compare how many kwh it would take for an electric heater to provide as many BTUs as you could out of one of those and through a heat exchanger.
    Mike
  12. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Are you using a dashboard camera? How did you tape that?
  13. JMD
    3,779
    1,282
  14. SomeRandomIdiot
    SomeRandomIdiot Junior Member
    29
    Considering TFS has rebates of $5,300 on 2012 PiPs still in stock (along with a money factor of 0.00001) , that a considerable discount one does not find on a non-PiP Prius.
  15. JMD
    3,779
    1,282
    TFS is offering a 10k rebate plus you get federal and state tax breaks on the RAV 4 EV
  16. SomeRandomIdiot
    29
    $10k rebates on the PiP or the RAV 4 EV? Which states? NE area is half that - still enough to bring it down below price of non-PiP Prius.
  17. JMD
    3,779
    1,282
    Andyprius1 likes this.
  18. john1701a
    12,840
    5,311
    58
    It is literally just a GoPro camera with an adhesive mount stuck to the dash. That's it... none of the fancy window-mounting & anti-glare gear I usually have to use... since it was ideal lighting for this particular drive. Any other time, the scenery would be over-exposed and/or the displayed under-exposed. Also, note that the refresh-rate of the Eco-Meter usually presents a lighting challenge too. It was a lucky timing.
    JMD likes this.
  19. JMD
    3,779
    1,282
    Nice job. Felt like I was in the car.
  20. El Dobro
    El Dobro A Member
    7,101
    3,280
    The Chevy s10 EV had a fuel tank used just for heat.
