EV + Gas on long trips
Discussion in 'Prime Main Forum (2017-2022)' started by bluzfan35, Jun 22, 2017.
  1. bluzfan35
    bluzfan35 Junior Member
    50
    55
    missouri
    Going on a trip next month and wondering what everyone was getting on a single charge plus a tank of gas on long trips?
    HPrimeAdvanced likes this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Each day on my US 2 trip out west from Michigan I would charge my battery at each of the motels I stayed at.
    Prius from Dad likes this.
  3. priuscatprimeguy
    2,730
    2,640
    I averaged about 70-76 MPH, Mt and Wy and ID speed limit is 80 MPH:eek:
  4. bluzfan35
    50
    55
    missouri
    My trip will be 712 miles round trip and i will leave here with a full charge and be able to charge at my destination leaving about 662 miles on ICE. Curious if i can make the whole trip.
  5. Prius from Dad
    Prius from Dad Senior Member
    724
    1,115
    Toms River, NJ USA
    I would say maybe if you can average 60+ mpg in HV mode. Using the HV battery as much as you can will help. Depends on your driving style, passengers, cargo load, A/C use and temps. Good luck! (y)
  6. bluzfan35
    50
    55
    missouri
    It will be August so who knows about the temps but it will be night driving so cooler with less traffic. Speed limit is 70 here and i usually set the cruise at 68.
    wrhaider and Prius from Dad like this.
  7. Dale Leonard
    Dale Leonard Member
    66
    47
    Hartland, Wi
    I averaged 52 miles in 1800 miles with only one charge. Donot use charge mode, waste of gas. Good luck.
  8. bluzfan35
    50
    55
    missouri
    I thought about charge mode for a minute then dismissed it.
  9. alexcue
    alexcue Active Member
    346
    311
    So Cal
    On the freeways here, the speed limit is 65, when you can run, meaning no or little traffic, you do under 70 and the trucks will be on your tail, these are on 5 lane highways. I would say my average speed on them is about 73, Once the speed opens up to 70 mph, I'm usually doing about 75-78. My trip to Yosemite which was about 900+ miles round trip (trips back and forth in park included) I averaged 55.7 going up and 71.4 coming back. I only technically recharged once before leaving, but because of the hills I could easily gain 20+ miles of EV on the downhill portions. I had one fill up.
    Edit: Using charge mode? I tried it, and I think it actually gives pretty good mileage, when you factor in what it adds. YMMV ;)
  10. bluzfan35
    50
    55
    missouri
    Dont know how much regen ill get but at 55.7 mpg it would make it very close
  11. john1701a
    john1701a Prius Guru
    12,748
    5,243
    57
    1,700 mile trip for me. 41 MPG on the way there, almost all highway with most of it at 80 mph using A/C. 50 MPG on the way back, without A/C.
    I took advantage of charge-mode too. It's very nice for when you get off the highway and need to wander around town, especially the next morning with a cold engine. In the evening, on the way to your lodging after dinner in EV is nice too.
    alexcue likes this.
  12. bluzfan35
    50
    55
    missouri
    Did you use charge mode most of the time?
