EV mileage
Discussion in 'Prime Main Forum (2017-2022)' started by ed4271, Jul 17, 2019.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    See how it levels off at about 75F and then starts to drop slightly just before the end of your measurements. If I was tracking, my measurements would go up another 20F and drop steeply right where yours start to hint at a drop. So, the warmer the better is not always true. At 95F, I get about the same range as you do at 35F. But at that sweet spot around 70-75, it's awesome. Someday I hope to see those temperatures again. We're looking at another 92+ day again tomorrow. :oops:
  2. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    Correct, no AC load. AC definitely affects EV range.
  3. jerrymildred
    11,517
    14,171
    Tampa, FL
    Big time down here. But it had an even bigger impact with my PiP. Prime's AC is far more efficient, apparently.
  4. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    my postulation was: 1. Start out with a full battery 2. full tank of gas (=?miles) 3. during last leg of 1 trip recharge EV battery with engine and then exhaust any motive potential. = how many miles?
  5. Tideland Prius
    16,683
    @bwilson4web you've done these experiments, right? Thoughts?
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    You might wait to hear from @bwilson4web for his experience on this. There are so many variables in this equation. How fast are you going? What kind of traffic are you going to have? What is the ambient temperature? What kind of terrain you are driving? Any AC (heat or cool) use? Any passenger or cargo in your car? All of them and many more other factors will affect the milage and EV range. It will be impossible to predict the precise range you will get.
    Assuming EPA published number of 55mpg and 25 miles of EV range, you will get 55x11.3=621.5 miles + 25 EV miles, total 646.5miles. I don't know how much of gas is used to get 80% charge for the last leg of EV, but the assuming the conversion is not 100%, your range will be little shorter than what you will get from all provided gas and charge at the start. So my guess is using a half-gallon of gas to get 20 miles of EV by CHARGE mode, thus total miles will be 7.5 miles shorter or 639miles when you hit dead empty.
    Dael likes this.
  7. bwilson4web
    16,552
    This is hard to explain as there were
  8. Tideland Prius
    16,683
    Were you planning on finishing that thought? :D
    Raytheeagle likes this.
  9. jerrymildred
    11,517
    14,171
    Tampa, FL
    I imagine that @bwilson4web will be back to finish that thought.
    In my limited experimentation, I got less total range using charge mode because of the losses involved in energy conversion. I didn't/couldn't document any numbers because it was such a variable situation involving changes in wind direction, hills, and stops for meals & bathrooms.
    My measuring stick was average mpg on the current tank. There was one stretch coming south on US19 in Fl. 65 mph speed limit. I did seem to get a tiny bit better mpg using charge mode and depleting the charge but it wasn't more than 1-2 mpg and that's well within the variation I'd expect from variations in wind speed and direction over the hours.
    I think a proper test would require an indoor track to eliminate wind, slope, and temperature variables. But just looking at the fact that you always lose energy when you convert from one form to another tells me that it would be very rare to gain anything with charge mode.
    Prius from Dad likes this.
  10. bwilson4web
    16,552
    Sorry, I got distracted.
    Reset your trip meter and optionally, carry a small, spare gas can securely. My rule of thumb:
    • EV mode when off the highway
    • use hybrid mode, preserve EV charge, after you get to cruise speed
      • Follow trucks, RVs, trailers, or towed vehicles using dynamic cruise control
    • The low fuel light comes on with ~1.5 gal remaining
      • Set the car to charge the battery to 80%
    • Continue until the gas runs out within 20 miles of a truck stop or gas station
      • Slow down on EV to reach a gas pump
      • If less than 5 miles to a gas station, add spare gas to tank.
    On a 600 mile trip, there will be biology breaks. If gas prices are relatively high or you are going 'for the record,' do your business and get back on the highway. At the pump, do your 'victory' dance (looks a lot like the 'I gotta pee' dance) and take a photo of the trip meter.
    ps. WARNING: if out of gas and EV charge, the car will coast to a stop. After adding gas, the negative battery terminal has to be removed for a power-on reset. Your tripmeter values will be lost but the car will start. Otherwise, the car will have to be towed to a very expensive Toyota service center.
    #50 bwilson4web, Sep 2, 2019
  11. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    Thanks Mr. Wilson!
    Sounds like a dangerous proposition! Scientists have to consider all possible outcomes!
    Jerry said losing about 1-2 mpg to charge. Towed for a power reset? really? how many times has this happened to people? Not a very user friendly experience. Thanks guys!
    Salamander_King likes this.
  12. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Correct me if I'm wrong, but on my Toyota Avalon Hybrid, the A/C compressor is powered by an electric motor .... not the ICE.
    I acknowledge that the ICE must generate electricity to run the A/C compressor, but it is minimal.(I would think)
    IF there is indeed a impact on milage from summer heat .... I'm thinking it must be from another cause. Air density? ICE in-efficiency? Rolling resistance from sticky hot pavement? And don't forget, motorist are much more prone to sit in line stopped at the drive-up with the A/C on.
    I would think that riding with the A/C on and the windows closed would more than offset any increase electrical demand from the ICE to run the compressor electric motor.
    Finally, I have not noticed any decrease in fuel economy on my Avalon Hybrid in the summer. If there is any, it's too small to accurately measure.
  13. Washingtonian
    Washingtonian Senior Member
    726
    621
    The impact on mileage from summer heat pertains to EV mileage, not ICE mileage. The traction battery is more efficient in warm weather than in cold weather. For example, in January I can expect to have 23-25 miles available after charging the car. In August, that has been 30-31 miles. Some get better, but I drive in the PWR rather than the ECO mode and am willing to make the trade off.
    Dael likes this.
  14. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Washingtonian - Thank you for your comment.
    Actually .... my comment was prompted by: " AC definitely affects EV range." from an earlier post.
  15. Salamander_King
    11,024
    8,980
    New England
    AC use definitely reduces EV range for PRIME. Heating by heat pump uses more battery power than cooling does. See this thread for detail. Estimated EV penalties for various heating cooling and lights | PriusChat
    Here is data from my AC load ratio which I believe is a measurement of traction battery use by AC (both heating and cooling) expressed as a ratio of battery charge used for EV drive. More AC use (higher AC load ratio on X-axis), less EV range (actual miles driven on EV mode on Y-axis) I got.
    #55 Salamander_King, Sep 3, 2019
    Arctic_White and Prius from Dad like this.
  16. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    question for you guys. If you charge your battery to 100% and then drive in gas eco-mode do you see the battery percentage drop despite not being in EV mode? Is this due to normal battery charge degradation over time, use of AC or electronics? I ask this as I noticed this the other day. I fully charged to 100%. The next day as I drove just on gas mode and noticed the battery percentage drop to 95% and then as the day went on to 90%. Thanks
  17. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    They say to charge right before you use it. Otherwise not good for battery to be driving around in EV mode when battery is charged.
  18. Salamander_King
    11,024
    8,980
    New England
    That's perfectly normal. When you drive PRIME on HV mode with the traction battery fully charged, for the first few minutes of engine warm-up ICE is not providing sufficient energy and depletes traction battery charge. Losing ~5% of battery charge on HV mode is normal. If your drive is too short, you will not gain back that lost charge. However, if your HV drive is a longer one you can usually regenerate most of the used battery charge, sometimes all the way back to 100%. I do this often enough when I charge my car full with the intention of saving the charge for my destination. Start a car with 100% charge on HV, lose some battery charge, but during the trip, I can gain back lost charge.
    #58 Salamander_King, Sep 4, 2019
  19. jerrymildred
    11,517
    14,171
    Tampa, FL
    That's why we keep telling newbies, "Just drive it." It doesn't get any more user friendly than that. No one HAS to experiment. And very few people do. They just drive it. That's what I do 99.99% of the time.
    Merkey likes this.
  20. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    The Avalon Hybrid like my wife’s NX300H always runs the A/C (or heat) off of the traction battery. That way if you are sitting at a light and the ICE turns off you’ll still have A/C. You won’t see the impact unless you’re creeping along on EV only. You might see the ICE power divert more to the battery if you watch the power flow on the display but the ICE is normally on most of the time in a hybrid like the Avalon or NX300h.
    Unsupervised!
