EV Miles estimate after Full Charge LOW
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bill3888, Jun 27, 2012.
  1. bisco
    52,863
    no idea, isn't there a timer button to start charging?
    lensovet likes this.
  2. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    Not that I remember.
    52,863
    ya, i have no idea.
  4. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    any photoshopper want this one?
    charger button - don't touch
  5. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    When the charge timer is set to begin charging later, plugging in will do exactly this:
    "Sometimes, when I connect the charge plug, I see the "charging" indicator by the plug, for about 20 seconds, then it goes Off, as though the charging has been completed; however, the "power" indicator on the cable indicates that the cable is powered and the dashboard display shows that the battery has not been charged at all!! "
    Plugging in later that same day, after the time on the car's clock is past the time the charge timer thinks it should start, charging will start and proceed normally.
    It sounds like you are "accidentally" setting the charge timer into action. This can be done by pressing the rectangular button (it has a clock face on it) above 3 small round buttons on the dash.
  6. vvillovv
    4,337
    1,519
    NY
    I've only used it once, but I wonder what the chances are of setting it without knowing it's been set
  7. bisco
    52,863
    is there a light?
  8. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    When the charge timer is "armed" a green clock symbol will flash in the upper right quadrant of the multi-function display. One can disarm the timer by pressing the button with the clock face on it.
  9. Sperling
    Sperling New Member
    Vancouver B.C.
    Holding the charging button in for a length of time will reset it. I had to do that per the manual, as my PIP would not charge after I plugged it in. The light at the charger would go out after plugging in.
  10. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    The charge timer switch is a toggle switch. Press it once to turn it on and press it again to turn it off. I've never had an issue with it. OP might want to try this while the car is plugged in to see if there is an issue with the switch. When I cancelled the time with the button the car started charging right away.
    iPad ? HD
