EV Miles estimate after Full Charge LOW
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bill3888, Jun 27, 2012.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    hope to be around when Toyota perfects atomic powered plug in (of course, it wouldn't be a plug in)
    52,745
    cold fusion, is it a pipedream?
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    52,745
    wow, wild whacky stuff!
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I guess we should stay on topic, so here goes: waaa, waaa, I'm only getting 11.6 miles EV :(
  6. bisco
    52,745
    you'd be doing much better with a plasma battery. oops!
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    LMAO
  8. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I've done this "test" a few times.. but when I first got my car, I never drove with AC or Fan to get more EV range. When it started to heat up, I drove home with AC and/or on the whole way. The first time I varied the fan speed and turned off the AC when the cabin was cool enough. I then tested it by just leaving it on the whole way. My commute home is 13 miles, slightly uphill, with lots of traffic lights. It normally takes me about 35 minutes to get home.
    I estimate that for my commute, using AC/Fan versus NOT using it, I lose about 1 mile +/- 0.5 miles.. its somewhat variable because of the many traffic lights I encounter. But I imagine the longer your commute time, the more impact the AC/Fan will have on your EV range.
    When I go home now, if its warm enough to even think about using AC, I just use it (I'm thinking of the battery too). Usually just 1 or 2 bars on the Fan level (the higher the fan speed, the more electricity it will take too). Oh, also, this was all in Eco mode, which is supposed to be easier on the AC usage.
  9. SocialSuzy
    SocialSuzy New Member
    22
    Sacramento, CA
    Hi Bill,
    Seems to be several of us experiencing this. I've been in contact with Toyota corporate. Please feel free to email me at: [email protected] and I can keep you in the loop with others.
  10. bisco
    52,745
    suze, you should pm bill. he has a life and doesn't have time to check these boards on a regular basis. your solution with toyota could be very helpful to him.
  11. Bill3888
    Bill3888 2012 vs 2006
    25
    Riverside, Ca
    Thanks for this - I don't think the dealer really did anything except charge it and drive around in HV to get it a little higher estimate on the dial,
  12. Bill3888
    25
    Riverside, Ca
    I've been preoccupied with my daughter buying a house and having her 1st baby so I haven't been able too keep up with the forum . Seems like I have a lot of reading to do. I have noticed a couple of interesting things though. Tonight when I started the car I had an Estimated range of 10.4 miles after charging. That's the highest it's been since the first week of charging at the beginning of May. . While I was watching the estimate it jumped to 11.7, kind of like a loose wire had connected, the display didn't flicker, just the estimated milage for ev reappeared as 11.7 miles. This tells me that the battery is fully charging all this time but for some reason the estimate has been for not showing correctly. Anyway long story short I backed out of my driveway and checked it and it had reverted back and showed 10.2. Something is definitely wrong but now I don"t think its the battery but the "system" loose wire , connection, programming, something??! I'll watch it for the next week of charges to see if it happens again. Obviously there's something intermittent here. I would appreciate it if anyone here who has noticed anything like this to let me know. This reassures me that the batteries are ok, but the remedy for the estimate may not be provable to toyota without a movie showing the actual change.
    The other thing I noticed is when I get down to .4 to .1 estimated ev range the "battery' symbol reverts to showing I have a full charge instead of an almost empty one. Weird!! I've attached a picture.
  13. Bill3888
    25
    Riverside, Ca
    I did == didn't help!!
  14. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Interesting/wierd. No pic attached?
    (And congrats on the grand child)
  15. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The system is working fine. But the data it has to estimate range with is so limited, the value gives the appearance of jumping.
    That is fine too. Looking close, you'll notice the interior of the indicator changes from solid to a series of stacked bars. That makes it easier to see the level when it's near or at depletion.
  16. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    What John said ^^^
    Worry less and just drive. The car is fine.
    Everyone needs to remember that the EV range is an ESTIMATE. The estimate is based on certain parameters and will change based on how you are driving (ie how fast/slow), as well as road conditions. I live in Ithaca NY where every commute involves a rather large hill. I just picked up my car yesterday but I know I will begin seeing my EV range drop once I have driven it more.
  17. bisco
    52,745
    the other day, i unplugged before it had finished charging. when i started, it said 15.5 miles. as i backed into the street, it jumped to 15.9. then as i started down the street, it dropped to 15.4. never had that happen before, but i think it might have been because the battery was almost full when i unplugged.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Something interesting is happening with my EV level. When I charged my pip at Consumers Electric (Chargepoint) my EV level was usually at .6 or 1.0. when I charged up my EV level would be at 10.6. Now that I'm charging at my apartment I'm charging my pip when it's got an EV level of about 5.0. When it's fully charged my level is at 11.8! go figure!
  19. bisco
    52,745
    that is strange, i also am having an odd thing. i was upto 16.2 ev range estimate and then, when i decided not to plug in the other day to see what i could get for hv mpg's, my ev estimate is down to 14.9 the last two days. i'm still driving 17 miles ev with the a/c on tho.
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I never go into HV. all of my trips are less than 11 miles between charges. never use A/C either ICE never kicks in also........ummm....well......almost never.....went to Electric Auto Association seminar and used HV
