EV miles go down after turning on HV
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pasaman, Feb 13, 2014.
  1. Pasaman
    Pasaman Active Member
    289
    115
    Southern California
    Situation:
    55 degrees fahrenheit, no climate controls on. Everything set to OFF. Heated seats off.
    Started 15 mile commute in EV. Drove on side streets for 3 miles in EV mode. Got on freeway and switched to HV. ICE turned on but EV miles went down by 1.2 over the next minute or so then stopped going down. This is despite being in HV mode and the ICE being on.
    This has happened a few days in a row now. Why do the EV miles go down so much after I turn on HV?
    Apologize in advance for so many "why does my PiP do this" threads! Just getting the hang of this piece of amazing technology.
  2. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    While the ICE is warming up, the battery provides most of the power. It's stealing the power to propel the car until the computer is satisfied. It's completely normal.
  3. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    ...and once the gas engine is warm, the computer controls will keep it on while the generator replenishes the traction battery to replace the borrowed EV miles, at which point, speed allowing (less than 63 MPH) the gas engine will shut itself off. If you have major climate controls running, the gas engine shutoff will happen a bit later.
    52,880
    and for more help, we have an FAQ sticky, put together by member lensovet, costing him much toil and hard work.:)
  5. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    The takeaway is that, although EV miles first appear to disappear, they will be returned to you as you continue on the freeway and will be there once you exit and choose to switch back to low speed EV driving (assuming that's what you do.) I'm more or less used to it now.:)
  6. DadofHedgehog
    681
    282
    northern Virginia
    This is where careful use of the EV/HV button comes in handy over the long term. Knowing your planned route(s), you can help yourself a whole lot by judiciously turning the HV (gas engine power) on when driving on the freeway and turning the EV back on when off the freeway. Of course, it's best to plan to get back home with an empty EV capacity no matter how you mix the use of HV and EV while enroute. Good Luck!
  7. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I generally switch to HV mode to heat up the engine about 2 miles before getting to the freeway to ensure the ICE is warm enough when I get up to speed on the freeway.
    uropip likes this.
