EV Miles increase.
Discussion in 'Prime Main Forum (2017-2022)' started by ed4271, Jun 26, 2019.
  1. ed4271
    ed4271 Member
    107
    64
    US
    I live in Upstate New York where the weather varies from season to season. In the winter time I usually get maybe 23 EV miles. Now I noticed I'm getting 36 EV miles. I noticed also what I'm more efficient driving my miles do increase when I finished charging. I know batteries do better in warm weather but if Toyota has stated that the batteries to get 35 miles I would have got a better federal tax credit. 20190626_084810.jpeg
  2. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    I believe the rebates are tied to battery capacity in Killowatt Hours not miles.
    jmarkd7, noonm and Prius from Dad like this.
    49,397
    the miles stated are from the epa test, not toyota
  4. Tideland Prius
    16,128
    Tax credit is based on battery capacity.
    jmarkd7 likes this.
  5. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    Llithium batteries have less performance loss when cold than do lead acid batteries. In cold weather you are using the heat pump more, the seat heaters, maybe more lights, maybe driving over and compressing snow. The lubricants in all the running gear are thicker when cold, thus more losses here.
  6. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    You would have received the same credit, for the 8.8 KWh installed battery capacity. The credit is based on battery capacity.
  7. jmarkd7
    jmarkd7 Member
    Virginia
    2018 Prius Prime
    Seems like 70-75 is the optimal temp for the batteries. If it’s hotter, my initial range is ~32. Otherwise it’s 33-34 in the warm months.
  8. fuzzy1
    10,165
    Separate from what others have stated (credit is not based on miles), note that car makers cannot legally advertise non-EPA EV ranges and MPGs.
    Your 35 miles is based on a gentler route than the EPA drive cycle and conditions , just as my 76 MPG trip on my 2010 Prius was also based on a easier, gentler route. But those are not standardized EPA conditions, thus not comparable to anything else and therefore banned from the advertising.
    ed4271 likes this.
  9. ed4271
    ed4271 Member
    107
    64
    US
  10. E-GINO
    E-GINO Active Member
    194
    206
    Rome, Italy
    So far the one below is my maximum recorded mileage extimation (hot days here!)
    Of course with A/C and ventilation switched off (and windows fully opened..)
    drash and Tideland Prius like this.
  11. Usle
    Usle Active Member
    317
    139
    Me
    2018 Prius Prime
    My 17 is now starting each morning at 23.1 in NH, I'd like to see 36, saw 33 this spring, anyone with any idea about this discrepency (36-23) I'd love to hear an opinion.
    Anyway, toyota states an average that will win if challenged in Federal court.
  12. fuzzy1
    10,165
    Not at all. They state the result of an EPA-mandated standardized test, which doesn't really match how much of anyone actually drives. Though the EPA has been rolling in adjustments over the years to make it less 'optimistic' compared to how typical people drive, which in turn has becoming continually faster and more aggressive since the national 55 MPH speed limit was abolished.
    Of course, many of the car makers 'fudge' the tests as far as they can, but the available room for that in the U.S. is limited. Euro tests have historically had significantly more room for such 'fudging'.
  13. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    Are you using AC? What is your monthly miles/kWh average looks like from your eco diary?
  14. ed4271
    ed4271 Member
    107
    64
    US
    It depends how efficient you drive. I know it sounds strange but when I am driving on the highway I set my speed control to 50 miles per hour in a 55. I drive with the B on so regenerative braking a lot more. I know it sounds strange but I drive with my windows open and don't use the AC. That's because winter is long up here it is always cold so why do I want the AC on to make me feel like it's winter time. Only when it's unbearable do I use the AC. But I still managed to get decent EV miles.
    Prius from Dad likes this.
