EV Mode and Hybrid System Indicator
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Gaudete, Jan 22, 2013.
  1. Gaudete
    Gaudete Junior Member
    71
    Dear all,
    Just bought a new 2012 Prius Plug-in on Friday. Still learning the ropes. These fora have been tremendously helpful - thanks to all who have posted.
    Here's my question: I've selected EV mode, and the EV mode indicator light is lit up as it should be on he dashboard above my steering wheel. As would be expected, to the right, the Hybrid System Indicator bar features a little car sitting on top of it with the letters "EV."
    However, after a few minutes of driving, the letters "EV" disappear from the little car in the Hybrid System Indicator. The indicator doesn't switch the to HV screen (where the main bar is divided into two halves), but remains in the EV screen (where the main bar is undivided, with a little nub on the left for "charge" and on the right for "power.") And the EV mode indicator light above my steering wheel remains lit.
    A few minutes later, the "EV" letters appear in the little car once again. Then they disappear, then they come back again. All along, I've had plenty of mileage left to go in EV mode (more than 6 miles).
    Is this normal behavior? Is this simply what happens when the ICE kicks in despite being in EV mode? (And the ICE definitely kicked in - I saw that on the Energy Monitor graphic. And I understand why - it's been very cold here [northern NJ].)
    Thanks in advance!
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ICE will come on if it's below 14 degrees F
  3. Gaudete
    71
    Thank you priuskitty, that much I get. What I'm trying to understand is the display.
    So just because the ICE came on, I'm not necessarily kicked out of EV mode?
    I'm still in EV mode (hence the EV mode light, and the EV mode version of the Hybrid System Indicator), but since I'm no longer running on stricty electric power, the little car in the Hybrid System Indicator loses its "EV" lettering?
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I think it's called EV boost mode. check out the One and only Prius Plug In FAQ thread, that may answer your question
  5. Gaudete
    71
    lensovet likes this.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Yes, normal. ICE kicks in so smooth, it is hard to tell. It happens when you asks for cabin heat or to assist the battery (got anemic due to cold temp).
    The system is protecting the battery and using the best fuel for the job. EV-BOOST blends both.
    To mitigate it, use the charging timer to finish right before you need to drive. Park in a warm garage if possible. Run the cabin heater until the battery gets warmer (it draws air from cabin).
  7. Gaudete
    71
    Thank you!
  8. bisco
    52,519
    i think you understand it perfectly. congrats on your new pip and welcome. all the best!
  9. lensovet
    2,615
    496
    Burlington, NJ
    yes, exactly :)
