EV mode invalid
Discussion in 'Gen 2 Prius Technical Discussion' started by Benjamin13295, Jul 16, 2018.
  1. Benjamin13295
    Benjamin13295 Junior Member
    62
    Slovakia
    why does it sometimes says that EV mode invalid , I have an EV button original on my Prius and when I have full charge and press the button it says EV mode invalid , why?
    52,762
    it only works within certain parameters of ambient temp, speed, battery level, etc.
  3. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    And, believe it or not, the HV battery being very full is one of the parameters that prevents EV mode.
    FYI, do not try and run your Prius as an EV. It is not an EV, it is a hybrid and works best when the petrol and electric motors work together. Let the control software dictate when and how much electric to add to the mix.
    EV mode is designed just to move the car a short distance (like 100 m) to shuffle it around a driveway, in/out of the garage, stealth approach to home late at night (last 50 - 100 m), etc. If you try and run it like an EV, you will get worse (higher) l/100 km not better (lower).
    Hope that helps.
    jerrymildred likes this.
  4. Benjamin13295
    62
    Slovakia
    Thank you
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I'd say the same. Also, if you're going to move the car in the driveway or something like that and want to use EV to save starting the engine, you need to push the EV button less than seven seconds after powering it up. If you wait till the engine starts, EV will be unavailable till the engine finishes the first stage of its warmup.
