EV mode. Is it really practical?
Discussion in 'Gen 3 Prius Main Forum' started by BrianWalton, Dec 18, 2011.
  1. Tideland Prius
    16,674
    True but it's an "easy" one (either make it yourself or buy Coastal Tech's EV mod unit). I have Coastal's unit on my 2005. I've used it more often than in my 2010 just because it's ridiculously restrictive (16km/h? really?)
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    But that's just because you're hacking into a non US option. Is there any way you can hack a gen3 to use the worldwide EV only speed limits? I mean 10mph/16kmh is poor to say the least. It's hardly worth bothing with.
  3. dz302
    dz302 Prius Rookie
    South Carolina
    I do this exact same thing. I have a long down hill run coming home, but when I turn into my neighborhood, I have a 1/4 mile uphill to get to my home. If I don't use EV, it's almost impossible to get up the hill because I have to depress the pedal to the point the engine starts, if not, I will crawl. If I use the EV, I can get up the hill with a decent amount of speed with the engine off.
    Aside from this, I hardly ever use it though.
  4. Tideland Prius
    16,674
    True.
    I don't know. No one has mentioned anything about it and what controls the difference in the two continents (could be as simple as a software)
  5. srevelation
    srevelation Junior Member
    25
    Pennsylvania, USA
    Well that explains why mine always pops out of EV mode at 10 MPH. I've never gotten it more than about 15 MPH even when warmed up -- thought it was perhaps an error that I wasn't able to go as fast as others. I do much better by light tough on the gas pedal in keeping it all electric.
  6. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    It's easy to use EV when you have a gauge showing coolant temperature.
    If above 155°F, you know that power in both the WHITE and RED zones on the Eco-Meter are available with a max speed of 24 mph.
    If cooler, that 10 mph cutoff becomes all too real.
  7. Rupert B Puppenstein
    Rupert B Puppenstein Active Member
    261
    126
    North Carolina
    I have no problem staying at 25 mph in EV mode when the car is warmed up. It appears the EV mode does not like when the car is not warmed up because when I have tried it then, I get the lovely not available message - can't remember the exact verbiage but it is along those lines. :(
  8. Jim Clark
    Jim Clark Member
    310
    22
    Northern VA, the 51st state (someday)
    EV Mode = NO ... PWR Mode = YES.
  9. Tideland Prius
    16,674
    EV Mode Currently Not Available? or EV Mode Not Available. Engine Warming Up?
  10. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    Brian,
    There are very specific situations where EV mode is helpful. Your best bet at understanding this is to read up on the Prius warm-up phases here on PriusChat. That will provide you with the technical answers, but allow me to help with some practical advice.
    First and foremost, EV mode is most useful when the i/c engine is fully warmed up and the battery is at full charge. If you are operating on the freeway and you encounter a traffic backup, EV mode is very useful. You might get anywhere from 1/2 to one full mile without the i/c engine running, depending on conditions.
    Another practical application is that last 1/2 mile to home, assuming you live in a housing development or other densely populated area. We routinely travel our last 4/10 mile in EV mode at moderate speeds using EV mode. My advice to you would be to learn how your Prius works, then work with it as opposed to against it.
  11. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I find it most useful for maneuvering the car between parking spots in my driveway/garage when you DON'T want to fire up the ICE. Otherwise, I find it to be like swiping a credit card and paying interest later (electricity to run EV mode isn't free due to resistance losses in both directions of current flow).
  12. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    The more I read the more confused I become. I had my 2011 Prius lll now for three months and have tried (Key word here is TRIED) to use EV mode several times but I go only a few hundred feet and it reverts back to ECO. Now my confusion is what is the NORMAL mode and how to get to that one. Don't see anything in the manual on that.
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Normal mode is when nothing is selected. Press any selected mode key to switch out of that mode and back to normal.
    Tom
  14. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    I had the same experience when I first drove mine, but with a little practice I am able to take advantage of EV when; it's warm (above 50 degrees), when I am not heavily accelerating, and when I am crawling in bumper to bumper traffic (below 25 miles and hour). Also comes in handy at stop lights. I also use it when I enter parking garages where the sprred limit is typically 15 MPH or below.
    Although I leave the car in ECO mode all the time, I try and take advantage of the EV switch as much as possible. In the summer months I can average between 52-56 MPG by being diligent with the EV switch and also avoiding fast acceleration from a dead stop...
