EV mode not engaging and rear battery fan always on
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PriusFan06, May 11, 2017.
  1. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Just guessing here, but if you are gently accelerating and cruising conservatively perhaps you are just using the electric motor. It follows that the HV battery will deplete and the engine will only come on to top it up. The Prius needs to be driven less conservatively occasionally and I find that keeps the SOC fluctuating. Incidentally, as long as the ICE stops the HV from discharging when too low, it's working as it should.
    Data Daedalus and kithmo like this.
  2. bbunge
    bbunge Member
    35
    33
    Southampton
    Never acted that way until the issue with the main battery cooling fan. Seems to be related to temperature as it was cooler the other day and the bars did not drop as fast. A/C compressor load draining the battery?
    Dealer service manager admits something does not seem right.
    P01M ?
    RCO likes this.
  3. Philliplewis590
    Philliplewis590 New Member
    Oakland
    I'm having the same issue with my 2010 prius. When I accelerate sometimes the battery fan kicks on. I have no warning lights or issues. Did the issue with your get resolved?
    51,935
    welcome!
    it might be as simple as cleaning the fan and intake grille. hopefully nothing more serious.
    how many miles on her?
    Data Daedalus and RCO like this.
  5. Philliplewis590
    Oakland
    I bought it at 115k miles it now has 138k as I drive for uber. Everything was going good until I got the air filer and second oil change. I took it back to the mechanic and we cleaned out the hv battery fan and the vent. It still kicks on after I drive for a while. I goes off but when it kicks on it's at a moderate rate. What could be causing this?
  6. bisco
    51,935
    has the weather been warmer? the fan has 6 speeds, and if the battery needs more cooling, the sound gets louder.
    it can also be a warning sign of the hybrid battery getting weak. hopefully not.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I think it automatically works it out - charging or discharging happens continually in a hybrid environment - and, both cause heat, which needs to be dispersed.
    It could be that your older fan is a bit noisier than a brand-new one, but still working fine. Personally, I can't hear mine on my Gen4 unless I put my head near it - but that could be my hearing too.
    Maybe someone knows how to check that it is working correctly?
  8. Philliplewis590
    Oakland
    I started when the weather was warmer. It's been cold here in the Bay Area and I've not heard it kick on as much. Also the battery was replaced at 115k before I bought it. I did just find out however it's a refurbished battery with a 5 year warranty.
    Data Daedalus and bisco like this.
  9. bisco
    51,935
    that makes sense.
  10. Philliplewis590
    Oakland
    Still doesn't explain why it kicks on. It's never done this before.
  11. PriusFan06
    PriusFan06 Member
    60
    33
    SF Bay Area
    Hello, no I never got this resolved. I took it into the dealership during my oil changes and spoke to two technicians and they said it was "normal" for it to kick in. My cousin has a 2017 Prius Two Eco and their fan does not turn on. In fact where he lives is much warmer than where I live. I drove his car and I cannot hear his fan. However my fan still continues to turn on from time to time and is loud enough for me to hear it.
    When I did bring my Prius for an oil change I mentioned this to them. They did run a dianostic on the hybrid system. They showed me a print out and all was fine. I still don't think its normal but not much I can do.
    RCO likes this.
  12. alanclarkeau
    7,045
    7,592
    This is the Gen 4 FORUM - I've reported your posts to the Moderator - hopefully he'll move them to the Gen 3 FORUM, where you'll get more relevant answers. There were considerable changes to the entire Hybrid Synergy Drive between Gen 3 and Gen 4.
    #52 alanclarkeau, Mar 10, 2018
    jerrymildred and RCO like this.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It may be that there is some imbalance on the fan making it sound louder. See if you can access the fan itself and check if the blades are all clean and intact and see if there's anything obstructing the fan.
    Data Daedalus and jerrymildred like this.
  14. bisco
    51,935
    it may explain why it kicks on; 1) warmer weather 2) refurb battery.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Agree with @bisco. I expect that you'll soon be getting a big ol' red triangle on your display. Refurbished batteries don't last long. Are your HV battery level bars going up and down more quickly than they used to?
    Data Daedalus and Prodigyplace like this.
  16. Fester
    Fester Active Member
    201
    198
    Ohio
    I can't speak for the Gen 4 (mine is a 2017 Prius 2 as well), but my 08' Gen II's HV battery fan would not turn on till the battery was above 98 deg. F. I've always used a ScanGauge to monitor various systems, being from an Engineering background. There still are no X-Gauge codes for the Gen 4 traction battery as I'd like to keep an eye on the temperature during warmer weather. I have not however heard the fan come on. There is an experiment you can perform that was useful for me with the 08'. Sometimes when something peculiar was occurring, I found that by disconnecting the 12v battery for a few minutes then reconnecting, which basically reboots all the computers, many times the problem would be fixed. No guarantee of course, but you never know. The bottom line however is finding out what the main battery temp actually is.
    Data Daedalus likes this.
  17. Philliplewis590
    Oakland
    I think I found the issue. I'm going to get the actual fan replaced.
    kithmo, Data Daedalus, RCO and 2 others like this.
  18. jerrymildred
    11,517
    14,152
    Tampa, FL
    Hope that's all it takes. (y)
  19. bisco
    51,935
    all the best!(y)
