EV-Mode Range??
Discussion in 'Gen 3 Prius Main Forum' started by swich2mac, May 23, 2009.
  1. swich2mac
    swich2mac Go Hard or Go Home!
    319
    38
    Franklin, TN
    Does anyone know the range the 2010 will get in EV-Mode?
  2. MarkM09
    MarkM09 New Member
    Kentucky
    If I'm not mistaken it's about a 1 mile range and it's supposed to switch out of EV around 25 mph. Seems like EV is more for parking lots. I'd think regular or Econ mode with the hypermiler pulse and glide trick would be more useful.. and maybe even fun to play with.
    I've never driven a Prius but this video seems like a good guide on how to get the most out of the electric motor [ame=http://www.youtube.com/watch?v=K1PPQ8N-95I]YouTube - Toyota Prius City Gas Mileage[/ame]
  3. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Remember this. All the energy used to power the electric motor comes from the gasoline burned in the ICE. So if you are wondering this to try to save fuel, you will not save fuel using the EV mode for extended periods.
    The range of in EV depends on 3 things:
    1) Your SOC (State orf Charge) the higher the state of charge the more range you will achieve.
    2) The terrain. Oviously a downhill slope will produce a longer range then an uphill slope.
    3) How fast you use the available charge.
    With all this said 1 mile is about right. Why do I say that, because very few people use the EV for propulsion, as it is less efficient in the long run then using the ICE efficiently.
    Hope this helps.
  4. Bwalls
    Bwalls Junior Member
    Warsaw, IN
    I picked up my 2010 Prius yesterday. Like others have posted the EV mode only works up to 9 mph. After that you get a message saying "Excessive Speed" and the engine starts. Not what I expected from EV. My info shows EV only good for up to 1/2 mile.
  5. NYPrius1
    NYPrius1 Active Member
    1,181
    125
    Middletown, NY
    I have a question. If you do not select a mode, what is the default mode?
    Thanks
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Normal.
    You disengage a mode by pressing the button again.
  7. XMAN LIVE
    XMAN LIVE "Just have Fun!"
    271
    23
    49
    Cypress TX
    What does ICE mean?
  8. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Internal Combustion Engine
  9. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    There has been different information published by Toyota on EV mode range. Some publications noted it as 1 mile and others as 1/2 mile. It is all very dependant upon the type of drive you are trying to use it on, but I'd say the 1/2 mile is much more appropriate for rating it. As noted many times before, don't think of EV mode as a mode you can use to drive the car like a Tesla or something like that. It's real benefit is for moving around a parking lot, moving the car in and out of a garage/driveway etc. That's not to say it cannot be used to help save gas under certain driving conditions but it must be used wisely otherwise it will actually hurt your mpg.
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    went to cancer fund raiser in Tacoma (about 25 north-east) started at 5.30 so we did the "I-5 crawl" and was in EV a few times and looked like we could do anywhere from 2000-3000 feet and mind you we never had more than 6 battery bars. so top off the SOC range and i guess a mile would be close...
    as far as mode goes, you can select either eco or normal as a default i believe since mine always starts up in eco
  11. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Yes, the car will retain the setting for ECO or normal when turned off and back on again. If the car is shut off in PWR mode it will just default back to normal...
  12. Tideland Prius
    16,206
    I thought we agreed that gliding was more efficient than EV-ing?
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    tried shutting it off in power mode, still came back on in eco. there is a setup screen that shows eco as the default, wonder if i could change it?? i will have to let ya know on that after the return from BBQ....at least that s if i remember to try it
  14. Tideland Prius
    16,206
    Well it assumes if you want ECO, you don't want to have to select it every time. I think that's the reasoning behind the software remembering ECO mode and not PWR mode.
  15. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    One note in the video, (great video btw) I wouldn't floor it to jack rabbit. I think it was John1701a's site that said it's peak efficiency combustion wise was closer to 70% throttle. So I would try to push it 7/10ths of the way down! GREAT video though, that is exactly how I normally do it.
