EV mode warm up
Discussion in 'Prime Fuel Economy & EV Range' started by AldoON, Jun 1, 2020.
  1. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    I still don't think the car is actually using more energy. I've watched temperature gauges on hybrid assistant, and nothing warms up particularly fast in EV mode. I expect the battery current would be about the same no matter what temperature if the HVAC is off. I think it's just getting the indicated SOC caught up to the actual battery level.
    How cold is cold? It's been 90 degrees in the day and 60 at night here. I wouldn't consider 60 to be very cold, but I guess relative to 90 it's colder.
    I'm also convinced that how "fresh" the charge is makes a difference. For example if you let it sit without charging for a few days, the SOC will drop faster once you start driving than if you charged it the same day or the day before. But I haven't been able to test it to be sure.
    jerrymildred likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I was thinking the same thing. We'd need to know what's meant by a "cold" car. Does that mean the engine hasn't been run or that you can see your breath inside the cabin?
    The battery does have heaters, but I don't know the temperature threshold for turning them on.
    AldoON likes this.
  3. AldoON
    AldoON Member
    108
    Milton, ON
    2018 Prius Prime
    Upgrade
    By hot car I mean the car has been running very recently and is warmed up.
    By cold car I mean the car has been sitting unused for a few hours.
    Temperatures have been in the 15C to 25C range. You can see in the pictures that the temperature was around 21-22C when I saw the battery deplete on a "cold start."
    I came home from work and let the car sit for about 3 hours on 6% charge before trying the drive.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    I haven't done the experiment myself. So this is only speculation but I think a drop in SoC is more the function of multiple factors. The temperature may be a factor, but that is not the only one. In order to compare the "hot" vs "cold" in your description. I think you have to do the "Hot car" in exactly the same driving condition as your "Cold car". So, in your example, for "Hot car", you need to drive the car for a while until you get the SoC down to 6% and park your car in your driveway. Then, start immediately again and drive 1 km and record the drop in SoC. Compare this drop in SoC value to "Cold car" by doing the same but parking the car for a few hours before driving the same 1km trip. Of course even with this setup, if the ambient temp changes or way you drive the 1 km is slightly different say due to traffic, then there will be other variables playing in. But do this several times, and if "Cold car" always use more SoC on the same 1km drive, then your theory is more or less proven.
    #24 Salamander_King, Jun 6, 2020
    AldoON likes this.
  5. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    My understanding is that the heaters only run while charging. They come on when the battery is somewhere around 32-34 degrees and turn off once the battery reaches around 37 degrees F. I don't think they ever come on while driving. If the battery falls below freezing it becomes very hard to stay in EV mode.
    jerrymildred and AldoON like this.
  6. AldoON
    AldoON Member
    108
    Milton, ON
    2018 Prius Prime
    Upgrade
    Yeah that's what I was thinking too. Maybe what I did for hot car + low SOC (starting at 11%) isn't totally comparable to starting at 6% like I did for cold car + low SOC.
    I'm planning to experiment some more and try and consistently start the drive at 6% for both hot and cold conditions... Will post an update whenever I manage to get a few runs in :)
    I'd be really curious to hear if anyone else sees the same behavior in their Prime.
  7. AldoON
    AldoON Member
    108
    Milton, ON
    2018 Prius Prime
    Upgrade
    Seems unlikely then, since the temperatures outside are well above that 37F...
    I can't really find a good explanation to why the charge drops so quickly...
  8. bisco
    52,792
    aren't canadian primes different in regards to battery heating?
    AldoON likes this.
  9. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    They just run the heater longer in Canada and Alaska, up to 30 days instead of up to 3 days, while plugged in. It's irrelevant for this discussion since ambient temperature is well above freezing. I only brought up heaters because jerrymildred mentioned them.
    bisco and AldoON like this.
  10. AldoON
    AldoON Member
    108
    Milton, ON
    2018 Prius Prime
    Upgrade
    Is there a way to see instantaneous battery consumption for the car? (kWh/100km?)
    Actual value, not that bar on the split screen (that is useless btw because the scale is too narrow... Almost always at zero or completely full... Grrr... )
    Might be useful to see if the car is actually consuming more energy... I'm thinking along the lines of letting the car sit at 6% for a few hours then turn it on and put it in drive but not move. Compare how much energy it draws in that state in"cold" and "hot" states
  11. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    The hybrid assistant app can show you instantaneous power. It updates frequently in real-time (at least with my Bluetooth OBD dongle).
    I watch the power consumption regularly, and I don't think you'll see any unusual consumption. If the car has been sitting for a while it charges the 12V battery, so "idle" power will be around 0.5-0.6 kW. If it is "warm" the "idle" power goes down to about 0.2-0.3 kW. But 0.3kW extra is not enough to explain a much bigger drop in SOC on a short drive. You could turn on the rear defroster and/or some seat heaters to cause an extra 0.3 kW load when the car is warm, and I don't think you'll notice much SOC drop a from that on a short drive.
    In addition, if there was some additional consumption, you should see the same effect at both high and low SOC when the car is cold. The fact that it only happens at low SOC means it is probably something to do with the battery itself.
    I still think the extra energy isn't being consumed or lost anywhere. The SOC is just being updated as the car "learns" the actual condition of the battery as you start driving.
    I'm not saying the battery is discharging itself over time. The discharge while parked would be extremely low, probably too low to measure unless you leave it parked for two weeks.
    But we know the range depends on battery temperature. In the summer you can get more range then in the winter, even if you could equalize all other variables. Here in Colorado we often have wife temperature swings in the winter, so that's as close to equalizing all variables as it gets.
    So when you see the car lose SOC faster than expected, it is probably just noticing that the battery voltage (or some other parameter we can't see, that it uses to calculate SOC) has changed while it was parked, and it updates the display to catch up. I'm not sure why it can't do that while parked when you first start it, but I suspect it's not possible to really accurately measure the SOC of the battery until it's under some load.
    Salamander_King and AldoON like this.
  12. jerrymildred
    11,517
    14,167
    Tampa, FL
    I stand corrected!! I went back to John Kelly's deep dive and he states at least twice that the heater only comes on while charging and if the battery is under about 2C. So it would not be a factor here anyway since it's not that cold and it's not on while driving.
    Tideland Prius and AldoON like this.
  13. Salamander_King
    11,024
    8,977
    New England
    LOL:ROFLMAO::ROFLMAO::ROFLMAO:
    AldoON likes this.
  14. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Oops. Should be "wide"
    Salamander_King likes this.
  15. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    You have to be more gentle with the accelerator (made easier by ECO mode). Mine shows all kinds of values in between near zero when hard accelerating uphill and full when coasting. On level ground moving around 45 mph I usually see it hovering around 10 mi/kWh (6.2 kWh/100 km).
  16. alinica2001
    alinica2001 Member
    94
    39
    Romania
    Hello,
    I can confirm the same results with "cold car + low SOC " on my car ( 2017 Advanced ).
    I'm always using GOM on miles ( km ) left and not percentage. I tend to believe that this has something to do with battery aging. I have 43000 miles on my car and I still can get around 38.4 miles with a full charge until ICE kicks in ( no A/C ). However, I've remarked the fact that with the same driving style, immediately after fully charging battery I can drive( let's say ) 4 miles with GOM decreasing only for 2 miles while the opposite happens when the battery is almost empty ( 4 miles GOM decrease while only 2 miles are driven ).
    Overall I'm happy as I can constantly go above 32 miles with a full charge.
    benagi likes this.
  17. Salamander_King
    11,024
    8,977
    New England
    Are you finding this when the car is cold and comparing it when it's warmed up? OP's finding is not so much about full vs near empty, but warmed up vs cold start.
  18. alinica2001
    alinica2001 Member
    94
    39
    Romania
    Immediately after charging battery, the temperature of the battery is quite high due to charging ... So I would not say my car is cold even if the car was not driven during last ( let's say ) 3 hours.
    But if I will drive from a fully charged battery until ICE will kick in , then I will see those results...
  19. Salamander_King
    11,024
    8,977
    New England
    To repeat OP's finding, you have to drive your car down to near empty 6% SoC remaining. And park your car at your home (or somewhere you can park your car over night. Drive the car right away or 12 hours (over night) later. Compare the distance you can drive from the same 6% SoC, when the battery is warm vs cold. Full battery is not a part of this experiment.
    AldoON likes this.
  20. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Do you have an ODB dongle to measure the battery temperature? It varies less than you might think. For example charging only increases it a few degrees, unless you're charging in direct sunlight. And the battery hardly cools off in 3 hours. It usually takes overnight to get significant cooling. In the summer my battery is usually around 95 degrees F if I've been driving or charging, and it usually stays at least 10 degrees above ambient overnight whether I charge or not.
