EV On/Off Charge Depletion Miles and Control Not Making Much Sense
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Susan4ET, Oct 18, 2012.
  1. 09 miles
    0 vote(s)
    0.0%
  2. 10 miles
    11.6%
  3. 11 miles
    20.9%
  4. 12 miles
    30.2%
  5. 13 miles
    14.0%
  6. 14 miles
    9.3%
  7. 15 miles
    9.3%
  8. 16 miles
    4.7%
  1. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    What are you talking about? Are you sharing some secret about this "rebooting"? If I do a new poll question for EV Estimate only to continue this discussion do you recon I should mention no "rebooting" allowed? If I'm guessing what you are doing that would explain how I drove the car off from the dealer with 13.1 showing--never to yet see anything but decreasing Estimates since.
    I don't want to reboot... I just want to know...
  2. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Rebooting the estimate involves removing the negative cable from the 12V battery for a short period of time. This makes the computer forget about all past performance and resets it to the factory default. It also resets all of your radio presets, and may reset a few other things. Doing it gives you a false sense of EV range, or at least a false sense of confidence in the EV range estimate.
    I don't think this can be said enough: the estimate is just an estimate of EV range based on past performance. What we don't know is how far back the computer looks to get an estimate. Is it the last X number of miles? The last Y number of charges? The average amperage being pulled from the battery for the last Z number of trips? How much regen did those trips produce? Are regen miles treated as EV miles? If you have the engine on, but are in EV mode, are those miles counted? I'm sure Toyota knows just how they compute it, but they're not telling us since it's proprietary information.
    The important thing at the end of the day (or rather, the tank) is your overall gas mileage. The higher it is, the better. Whether that happens because you drove a lot of EV-only miles, or you blended on the freeway at 65+ MPH, it doesn't really matter, just that it's up.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Susan, I'm sorry but charge drive and enjoy your car. Don't worry about what YOUR estimate says in comparison to others, it is quite meaningless. If your driving style or terrain is such that you get 9 1/2 miles from a charge on pretty much the same route then that's how it'll be. Yes, maybe improving how you drive can improve that but by how much? probably not alot IMO. Again, drive and enjoy your new car is my opinion to you.
  4. devprius
    devprius /dev/geek
    979
    291
    I have seen my EV miles drop and then come back up when switching from EV to HV mode. However, I'm willing to concede that the full charge EV miles may not come back. I deliberately started out in HV mode this morning, my EV miles did drop a fair amount, and never quite came back up to the level when I started out.
    However, I have frequently left work in EV mode, traveled for a couple of miles, gotten on the freeway, switched to HV mode, continued to watch my EV miles drop until the car was warmed up, and after about 10 or 15 minutes, watched the EV miles climb back up to the same level as when I got on the freeway. Now, this is usually in stop-n-go traffic, so there's a lot of regen going on, which may be confusing the issue (or my conclusions). I'll have to pay more attention to what conditions this seems to be happening in.
  5. Ayerscreek
    Ayerscreek New Member
    16
    Newberg, Oregon
    My estimate EV was pretty consistent all summer long, but since taking a long trip, the temperatures getting colder, and my lead footed husband driving the car, it has decreased almost a mile and seem to be decreasing more as temps are getting colder. So a couple of days ago I did a little experiment. When it was about 60 degrees out, on full charge, I turned the display off and the fan off. I drove under 45, keeping the HSI low and watched my actual miles. I had to stop a few times to let traffic pass but accreted slowly. Also, since we have a number of hills, I went up gently and glided down. After depleting the EV, my actual EV miles were 14.2. This assured me that the temps and lead footed hubby are probably to blame for lower EV estimates and nothing is wrong with the car.
    To learn how to drive the car, watch the hybrid monitor. Compare the miles driven with what is left and how long it takes to deplete the miles. I was really surprised to find how much a steep hill can deplete the EV. Also gliding down gentle slopes add or preserve EV. Long stops, even in drive through windows or car washes also can drain. But like mentioned by devprius, it's the total mpg that count in the end. Through watching your gauges, you'll learn the routes your car likes and places that you can plug in around your route that really helps your total mpg. I can get pretty obsessed, my hubby can care less, but it's been a total blast for me to drive and the gas I am saving is making my payments. Can't ask for more.
  6. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Mark... Can you reset the poll so I could, if I wanted to, create a new less ambiguous poll--or none at all please?
    I suspect now more then ever that the EV miles others have mentioned getting have been as ambiguous as me focusing only on my estimated EV miles shown right after a full charge. And if others are getting real estimates after a full charge of 14 miles while driving normal speeds with electrical loads on as required then there is something I'm missing in the picture that I must continue to resolve.
    I think now it may be pretty clear that the reason I drove off the dealers lot with an estimate of 13.1 miles showing is because the computer had recently been rebooted. That alone resolves one thing I have been perplexed about.
    Thank you.
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I can't reset the poll but I can just close the thread if you'd like.
  8. lensovet
    2,615
    496
    Burlington, NJ
    Honestly, I actually feel like Toyota should have eliminated this number from the display altogether. It makes sense in a pure EV like the Leaf or Tesla because the amount of charge left will have a direct impact on the route you take and whether you charge or not. But on the PHV, the only thing that matters is a) when it's full and b) when it's about to run out, so that if you're close to home/charger, you can try to drive a little gentler to prevent the ICE from kicking on right before your trip ends.
    remember, this car gets 50+ mpg in gasoline mode. That's 1/50th of a gallon per mile. The difference between 10 and 15 miles of EV range is 0.1 gallon. There's no point in wasting even a second of your life debating why you're seeing one number vs. the other – both in terms of environmental and financial impacts.
    Anyway, just drive the car. It's pretty awesome.
    I mean, for most of their history, gasoline cars had just simple analog fuel level gauges without any "distance to empty" estimates and people seemed to get by just fine with that
  9. Nope, no closing of thread! A lot of theories so far, but nothing provable. I think of rebooting as a new beginning. So right now, my HSI consumption shows 437 mpg for today's trip. Ratios are: EV 93% and HV 7 %. Rebooting and the battery disconnect proved very useful on my 2005 Prius, I expect the same with the PIP.
  10. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    Susan....I did not mean to come off this way...sorry bout that.
    In my sig image, you can see im averaging 125mpg for nearly 1000 miles, For me to achieve this I have to drive accordingly, and also have an approx EV ratio of 50/50. If you can use EV 50% of the time, you will get mileage around 125mpg when driven like a prius should be. Not like every other driver out there with jack rabbit starts and quick stops at lights. Learning to brake slowly and evenly, allowing for max regen is just as important as slow starts and very even acceleration.
    I always tell people,....reset trip A in morning....leave the house and try a 30 mph drive(using google maps) for the entire drive, watch your HSI the entire way, keeping it at or under 20%. If you do this, you will see 15miles on your trip A. Do this enough and your ESTIMATE will increase each day. That IMO is COMMON SENSE.(no offense)
    Now, Im going to attach A picture from my SCREEN....this is where my EV RANGE has increased to after about a week of me hypermiling in EV mode. 14.1EV ESTIMATE(when fully charged in AM)
    Now the last 3 weeks I have had to travel alittle further, and have not had the luxury of going slow due to having to take roads/route that include a 55mph and 45 mph.....Because of this, my EV range the last couple weeks has gone down slightly, its now down to 13.7 in the AM after charge.
    The moral here, is the same as car computers have worked for many years when calculating MPG. They take your MPG each and every moment, and they continue to AVERAGE them in forever..... So the fact I drive 6 weeks getting approx 15 EV miles(actual) means the car will remember how many times, how long, i kept getting those great EV miles. Now i only drove the car for 10EV miles for a couple weeks total, so that is less then the higher range. In other words, if i drive mostly getting great ev miles, the crummy trips where i have to accelerate faster wont mean as much overall. Its just math, and averaging.
    The reason many in this thread are getting alittle short with you...is that you dont seem to read what we are telling you, its like you want a magical answer that does not exist.
    also, FYI....each car comes preset from factory at 13.9 , at least that seems to be the most common INITIAL EV RANGE when new. Some guys have gone up, most have gone down.....all relative to your HSI, its like a tachometer sorta(not really) the higher HSI is, the more fuel/battery you use. I say this is common sense. (again no offense to you)
    Dan
  11. bisco
    51,965
    other than this thread and social suzy, ev range hasn't confused that many people.
  12. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    1. Mark, please leave the thread open.
    2. Noticed in my drive today that started off estimating 9.8 that in accessory mode I turned off the A/C and the estimate jumped from 9.8 to 11.1. I've not tried duplicating this yet. Even so I only made 9.4 actual miles with the 11.1 mile estimate. This still has me dumbfounded because I drove speed limits carefully that ranged from stopped to 55 mph. I did note the OAT at around 48 F at one point. A/C, lights, and Nav off may have affected the estimate but had no affect on the actual EV miles.
    3. I think I will pull off the 12 volt battery ground once to cause this 'reboot' and see what else gets reset if any such as cell phone Bluetooth pairing, or GPS addresses? And of course, what effect this has on the EV estimate. I'm only going to do this one time for the hell of it.
    4. Tomorrow I'll make an EV only run to fill the tank up + 3 clicks (if I can get the guy that fills in Oregon to do it) and start my trip bright and early Friday morning.
    5. I expect to use up the EV estimated miles but will record actual miles for all events including bar to bar mileage on the fuel gauge. I won't check the 'miles to refill' on 0 until other times when I travel with my 2 gallon spare tank.
    6. I expect the entire trip of at least a couple thousand miles to be HV (except for the ~ starting EV only). I am not expecting to use any charge stations even if I find them. And I think it might be just as interesting if I don't charge up EV. I'll record and reset A and EV/HV Ratio 1 each time I fill but keep B and EV/HV Ratio 2 for overall.
    What will you guys do while I'm gone on the trip?:LOL:
  13. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Yeah, I can't figure out why my post has confused the lot of you so much.:ROFLMAO:
  14. rockerdan
    427
    83
    Wheatfield NY
    Wow, you did not read one thing i wrote(on the bold) 55mph hardly qualifies for "good EV miles"
    also, FYI its the FAN not just AC. fan on/off will change your estimate, this has been talked about many many times here along with the many other EV range threads on this forum.
    Dan
  15. bisco
    51,965
    won't you have internet access? i'll be checking into a spa for some r&r.:D
  16. Ayerscreek
    16
    Newberg, Oregon
    This is pretty off track, but here goes anyways. This morning when I started the car, the fan was on with one bar. I turned it off immediately but then noticed that the mpg was only at 20 rather than the regular 999. When I turned the motor off, my mpg showed as 999 for that short trip. I had to reset trip A to get the 999 back rather than the by the 60 (mpg was building up pretty fast). Is the mpg also an estimate in the HSI display and if so, will the fan really effect mpg that much?
  17. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Don't worry about it Dan... I'm not putting the car up on blocks or driving it at 33.246 mph in a 55 mph zone just to climb the stupid EV estimate up.
    Regarding the fan... yes, it is always running to some degree when I punch Auto either for heating or cooling. Funny the headlights and Nav unit had no affect but the fan makes such a marked difference. I wonder if you'd get the same delta difference driving actual miles? Of course you know me. I drove with the fan off but still didn't even make the lower fan on estimate.
    So I've finished my 'reboot' experiment and discovered the estimate now at 13.4 BUT IT WILL ONLY Bleed off like before until it ultimate settles down again probably around 9.8 [9.4] or so with the fan off... [Oops, I think 9.4 is my lowest point estimate with the fan on.] So my reboot for the moment only got me to 13.4 but not 13.9 miles EV estimate. I wonder if I drove it around the block real slow once would cause a top off charge of sorts and maybe tip the stupid EV estimate closer to 13.9?
    Regarding the Bold type... Are you trying hard to tell me that that if anyone drives a variety of normal speed limits and traffic you won't ever see 14 estimated EV after a full charge? I could have sworn I read posts here where some have done that or better? But perhaps those who have claimed 14 or more have drifted into describing actual EV miles and not been talking about estimated EV miles after a full charge?
  18. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Yes I will! Guess you'll have to put up with my posts now with no breaks.
  19. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Can't fool with this PiP computer. It must know who's been driving it. After driving around the block 0.6 EV estimated miles and 0.7 actual miles with fan off and headlights on and not exceeding 13 mph culminating with a 0.6 hr recharge estimate the new estimated EV miles result is ... 13.3 miles... down 0.1 miles since the 'reboot'.
    Is it possible that the computer recognizes drivers who have been able to regenerate significant amounts of EV during the course of their drive even though the initial EV miles were spent and that this is what generates a bonus increase to the next days EV estimate after a full charge without getting ridiculous? I have yet to demonstrate any of this myself as I think my trips have been to short and I don't pulse and glide, hyper-drive, or go down any steep enough grades yet.
    If going down a long grade at 65 mph and regenerating for an extended enough period at that speed with or without using 'Brake' does the HSI change to reveal you have so many new EV miles you could automatically use when your speed drops below 62 mph? And of course the loss won't count if you are below 62 going up hill with EV off?
  20. lensovet
    2,615
    496
    Burlington, NJ
    Regarding your last point, yes. I took delivery in Springfield with the car completely empty and drove it to Berkeley immediately after with no opportunity to charge. Due to the grades near the OR/CA border, I was able to regen about 3 miles of EV range. 2 of those were used on the highway as I continued my drive, but about 1 mile was left when I got off the freeway and allowed me to get halfway home in pure EV mode after getting off the highway.
