EV or EV auto
Discussion in 'Prime Main Forum (2017-2022)' started by EV Happy, Dec 30, 2019.
  1. drash
    drash Senior Member
    2,600
    1,339
    Upstate NY
    XLE AWD-e
    In EV Auto the ICE runs to add power only after you put the pedal (actually the Energy Indicator) into the power area and leave it there for at least 3 seconds. Yes the ICE and motors combine and the effect is rather exhilarating. Both showed arrows going to the wheels for the brief period I had my accelerator floored. I did it twice and once you let off the pedal pressure it will go into standard HV warming to either get the Cat up to temp or cabin temperature whichever takes the longest time. It’s kind of disappointing that the effect is so short lived. Maybe I’ll try it in the spring again and instrument it.
    Unsupervised!
    Dael and Salamander_King like this.
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Thanks for the info. Yeah, I have never had an occasion to floor the pedal in my 2+ years of driving my PRIME. For me the highway marging only happens getting on the interstate, but that is over 50 miles away from my home. I am either done with EV range or if saving the EV range, I would be driving HV. That EV AUTO + flooring the pedal sound like the S+ system available on my son's Honda CRZ hybrid. I tried it once on a highway, and was fun, but again, I would have no real use for that functionality 99.9% of my daily drive.
  3. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    I mainly use the ev auto when I want to use electric which i do on a part of my commute with lots of turns, up hills and down hills at 25-55mph speeds,basically the canyon part of my commute. And adds quite a bit to my typical gas mileage too and I find the electric a bit easier to control and more fun on that part of my commute rather than using gas.
    Randi likes this.
  4. RustyRaven
    RustyRaven New Member
    Ventura County
    2020 Prius Prime
    Any update to this feature? It’s May 2020 and my 2020 Prius Prime does not appear to have a way to change the default. Still searching the manual for some information about default settings; so far no luck.
  5. Randi
    Randi Junior Member
    71
    23
    Prescott Valley, AZ USA
    2020 Prius Prime
    EV is the default. I like to use the EV Auto.
    TGrracie and Tips like this.
  6. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    EV is the power on default. Currently, there is no way to change that.
  7. Randi
    Randi Junior Member
    71
    23
    2020 Prius Prime
    I use the EV auto then switch to EV/HV for Highway.
  8. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    I found in EV mode my acceleration is wicked if I need it. What are you doing?
    TGrracie likes this.
  9. Randi
    Randi Junior Member
    71
    23
    2020 Prius Prime
    Try the power mode when driving in HV . Acceleration is increased.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    EV is the power on default and I would expect it to always be that way since the design imperative with this car is to burn as little gas as possible and pollute as little as possible.
    As for acceleration, it is the same whether it's in ECO, Normal, or Power; it just takes a different amount of pedal travel to get that level of acceleration.
    Randi and TGrracie like this.
  11. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    "In EV Auto the ICE runs to add power only after you put the pedal (actually the Energy Indicator) into the power area and leave it there for at least 3 seconds."
    It also runs the engine when traveling with the cruise control and an uphill section is reached. On a hilly trip that exceeds the battery range EV Auto yields lower gasoline consumption.
  12. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    I can't see how that makes any difference over just leaving it in EV mode. In fact, you will probably use more gas because you will probably drive up the hills faster because EV Auto puts out more power, and thus you will use up more gasoline.
  13. MikeDee
    1,581
    597
    No, it's not wicked. It just seems that way because of the throttle mapping and low end torque. The power output is less than the other modes and flatlines around 60 mph.
    jerrymildred likes this.
  14. Loriann
    Loriann Junior Member
    Rochester ny
    2020 Prius Prime
    I just purchased my Prius prime last Wednesday and am researching about the car and trying to learn the best driving mode. That being said, what is ICE?
    Dael likes this.
  15. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    Internal Combustion Engine.
  16. Loriann
    Rochester ny
    2020 Prius Prime
    Thank you.
    is it better to drive in EV our EV auto? I drive 20 each way to work and want to get the best GPM I can. Thank you.
  17. Bob Comer
    708
    460
    That's a hard question to answer actually. If you don't need bursts of power at highway speeds (over 50MPH or so) EV would be the most efficient, but if you do need it, I'd use it because there's not a lot of high end power in EV mode.
    I never use EV Auto, but I drive most rural roads and in town.
  18. Tips
    Tips Member
    128
    66
    Grand Forks, B.C. Canada
    2020 Prius Prime
    I like ev auto for all day driving! I enter ev auto and let it manage the trip! That way you can relax and let the prime do the thinking! So far the results are great and it gives you more time too enjoy the trip. The car usually brings numbers of 3 too 3.1 ltrs.per 100 kilometer's . I usually set my speed at 93 kilometers per hr.
  19. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    can you charge at work? Sounds like no. there was a couple on a tour of some flat island looking land that got 40 miles on a charge but not in traffic. If you could finagle a charge at work you'd be golden!
  20. MikeDee
    1,581
    597
    The best strategy is to drive in EV mode for the slow speed parts of the drive, and HV mode for highway speeds. EV Auto is just for giving you more power/acceleration over EV mode for when you need it, like for merging onto a freeway or passing on a two lane road. EV Auto is not for economy.
    AldoON likes this.
