EV owners abusing public chargers
Discussion in 'EV (Electric Vehicle) Discussion' started by bwilson4web, Sep 13, 2021.
  1. bwilson4web
    16,012
    I shared this with our local Tesla group:
    • tight loops - this puts extra stress on the conductors. Called 'work hardening', copper can become brittle, break, and the cable needs to be replaced.
    • lying on ground - in a wind, the rough surface wears the outside insulation leading to early cable failure. It is also a trip hazard for anyone walking by.
    • loop on loop - this adds weight to the cable putting stress to pull the cable from the charger. Once separated, repair is expensive and time consuming.
    If you've seen similar charger abuse or anything I've left off, please share images with this thread.
    Tideland Prius and jerrymildred like this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Saw something sort of similar on our vacation trip but didn't take a picture.
  3. hill
    8,640
    If folks had a buck for every cable untangled & unwound & unknotted, they would would be able to travel several hundred miles.
  4. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    I remember Tesla had a 'robot snake' thing they prototyped that was a metal shielded robot arm that would automatically unfurl and plug a cable into your car to charge - always thought that was nice not because it saved you plugging in, but because a lot of people have problems coiling cables and kinking them and this would have bypassed all those issues.
  5. bwilson4web
    16,012
    As other locals have shared, malicious teenagers are also a risk to free, J1772 chargers. Hopefully they smoke tobacco.
  6. bisco
    51,154
    the gas station model worked well for a century, other than the random armed robbery or cigarette explosion.
    donbright likes this.
  7. t_newt
    t_newt Active Member
    217
    246
    Tight loops reduce the current rating of the cable because the heat can accumulate: it doesn't have whole length to dissipate the heat anymore.
