EV range—brand-new 2021 Limited vs. 2020 XLE with 7,000 miles
Discussion in 'Prime Fuel Economy & EV Range' started by Gokhan, Nov 20, 2020.
  1. Gokhan
    Gokhan Senior Member
    6,217
    2,465
    Paramount CA
    I'm not sure how much it increases though. Nothing operates really once the charging stops.
  2. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    I checked on my 2020 PP, the difference is about 0.1v drop in 24 hours period with or without a charging cable attached after the charge is completed. I did it only for 24 hours, but if you keep it plugged for a longer period, it will drain the 12v battery below 12.0v in less than a week compered to taking about a month. As the manual states, this is due to the system checking the charging operation continually if the charge port is open and the charging cable is attached.
    #62 Salamander_King, Jan 15, 2021
  3. Gokhan
    6,217
    2,465
    Paramount CA
    Really? That's a lot of power drawn and it hardly makes any sense for a function that can basically be run from a watch battery. If that's the case, it's a really poor design by Toyota.
  4. Gokhan
    6,217
    2,465
    Paramount CA
    Update: I achieved a new EV-range record of 45.1 miles round-trip on 100% SOC. The temperature was in the mid-to-high 60s. I drove between 25–35 mph for most of the trip, occasionally hitting about 40 mph, synchronizing with lights well. The hardest part of getting the best fuel economy is to adjust the A/C temperature. I find in particular that the heating robs a lot of fuel economy, cooling perhaps not as much. Note that this is round-trip; so, I am not coasting downhill to get high fuel economy. The eco diary showed 7.2 miles/kWh.
    #64 Gokhan, Mar 30, 2021
    Leto, Tideland Prius and jerrymildred like this.
  5. Tideland Prius
    16,559
    WOW! Fantastic! This is strictly in EV mode, right? No HV shenanigans?
    Thebakerman and Gokhan like this.
  6. Gokhan
    6,217
    2,465
    Paramount CA
    Yes, this is pure round-trip EV driving, very gently, with no HV driving mixed in.
  7. Thebakerman
    Thebakerman Member
    149
    60
    You know I got the 2021 LE and the wife a limited. Such a great deal right now! Anyways I never in a million years thought I would get the MPG I was getting over the regular prius! I'm averaging over 75MPG. My 2020 regular prius only got about 52-55. Wow!!! 200 miles avg a day with just ONE plug in per day! AMAZING! 20210402_095748.jpeg 20210402_095240.jpeg
    Gokhan likes this.
  8. Gokhan
    6,217
    2,465
    Paramount CA
    Try to set the A/C to just below or just above the outside temperature so that you can bring the A/C load down to 2–3%, which will make your MPG and miles/kWh even a lot higher.
    Thebakerman likes this.
  9. Thebakerman
    Thebakerman Member
    149
    60
    Will do. Thanks!
    LOL
    That's funny and normal. Also you are in a enclosed space. This will amplify the sound by 2-3 times
    #69 Thebakerman, Apr 2, 2021
  10. Gokhan
    6,217
    2,465
    Paramount CA
    New round-trip EV range and miles/kWh records: 47.0 miles round-trip on 100% SOC and 7.6 miles/kWh round-trip!
    I took the advantage of the empty streets and drove about 25 mph to and from the grocery stores. I would probably achieve 50 miles if I didn't have the groceries loaded on my way back.
