EV range compared to Gen4
Discussion in 'Gen 5 Prius Main Forum' started by NHCLCR, Sep 7, 2023.
  1. NHCLCR
    NHCLCR Junior Member
    23
    Albany, NY
    All,
    For those of you that had a Gen4 Prime and now a Gen5 Prime, what kind of increase in range are you finding in Gen5.
    Barry
    52,863
  3. NHCLCR
    23
    Albany, NY
    Sounds hopeful. Just checking to see if the figure pans out in real life.
  4. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    There are a few YouTube videos of people getting quite a bit better than advertised EV range. I hope that’s the case for me when I get mine soon :)
    obviously, if you have the pedal to the metal everywhere you go, you can probably expect to get worse than advertised.
  5. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    You don't own either, and the EPA estimate for Gen 5 SE is 76% higher than for Gen 4. ;)
  6. bisco
    52,863
    That sounds wrong, but my not owning either has no more relevance than you owning one.
    Do you have a link to the epa estimates?
  7. GeoJ
    GeoJ Active Member
    225
    203
    United States
    I have been getting upwards of 45 miles in pure EV mode with 2023 XSE. So that's a bit higher than the published range. I don't know what Gen 4 gets.
    Blizzard_Persona likes this.
  8. Mr.Vanvandenburg
    1,361
    665
    2020 Prius Prime
    Must be a small sample to get info from people who have had both. On my 2020 I get about 5 miles per kwh, more like 5.2 usually, all town driving. What the 2023 owners are getting I don’t know. I find mi/kwh plummets on the highway to about or a little above the epa range of 25 miles. If the 2023 people are getting in the mi/kwh, then it can be guessed about what their ranges are. It varies a lot and is very sensitive to driving style.
    I went from a Volt with a larger range to the gen 4. I see no difference in my use on electric between them because I always charge before it’s depleted anyway, almost always. So I am more than happy to have the lighter battery pack and better mpg on gas with the Prime. A higher range in a 2023 to someone like me absolutely makes no difference except in rare instances.
    #8 Mr.Vanvandenburg, Sep 9, 2023
    Louis19 likes this.
  9. Andy2
    Andy2 Member
    79
    52
    Victoria, B.C.
    2022 Prius Prime
    Technology
    I’m routinely getting 39 EV miles on my Gen4 2022. City driving.
    Gokhan and Louis19 like this.
  10. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    (EDIT) 35 EV miles i get in city driving , on highways i usually get 28EV miles with air conditionning at 100KM/H
    Lose 10% with snow tires ....and lose an other 20% in snow .......in sub zero territory ICE kicks in for defrost and heating because the heatpump cannot handle the cold.:eek:
    #10 Louis19, Sep 9, 2023
    Gokhan likes this.
  11. Gokhan
    6,715
    2,672
    Paramount CA
    Gen 4: 25 mi
    Gen 5 SE: 44 mi
    Gen 5 XSE/XSE Plus: 39 mi
    Data on Toyota website.
    #11 Gokhan, Sep 9, 2023
  12. bisco
    52,863
    thank you, i sit corrected. i forgot that the se got better range and mileage. but i'm still correct about the other two, without owning either :p
  13. Trollbait
    12,831
    The LE, either hybrid or plug in, is the replacement of the gen4 L Eco.
  14. Gokhan
    6,715
    2,672
    Paramount CA
    How? L Eco and L had the same wheel/tire size. The only difference between LE/SE and higher trims is the wheel/tire size.
  15. bisco
    52,863
    What was L eco range?
  16. Gokhan
    6,715
    2,672
    Paramount CA
    He is talking about mpg.
  17. bisco
    52,863
    Oh, sorry. I thought this thread was about ev range
  18. Gokhan
    6,715
    2,672
    Paramount CA
    But the EV range will somewhat correlate with the mpg on a PHEV.
  19. bisco
    52,863
    So what’s the L eco epa range?
  20. Gokhan
    6,715
    2,672
    Paramount CA
    L Eco is an HEV, not a PHEV.
    You can scale the 44-mi BEV range on Gen 5 SE by mpg, and you get 41 mi for XSE/XSE Plus, which is correct as the 39-mi EPA range within the uncertainty in the least-significant figure crawling in the calculation.
