EV range declined slightly
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kong_konger, May 10, 2012.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    don't know. The test? I don't understand your question
    52,854
    if they are showing 16kw, perhaps 2.7 is not correct?
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    the PIP's usable battery capacity is 2.7 kw. The Nissan Leaf is closer to the PIP"s curb weight. You can enter your own battery capacity and curb weight on each car
    52,854
    if it's 2.7, why does the ratio screen say 3?
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    my Kill A Watt say's 3.0kwh but usable kw of the battery is 2.7kw due to charging losses (heat)
  6. bisco
    52,854
    interesting. i could have sworn others said 3kw and 3.3 due to losses.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    80% of 4kw is 3.2kw SOC assuming no resistance of the wires to motor.
  8. bisco
    52,854
    i have to sign off, but i would love to get to the bottom of the descrepency in ev range.
  9. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    YMMV
  10. hill
    9,038
    Battery efficiency can take a major hit is cold temps and those days are on their way. Once folks here on PC that live in the super frosty winter areas start reporting EV ranges in January - I suspect some of the Prius newbies will really start to worry. But it's all part of the 'YRMV'.
    Like all things electric . . . times a changin' - and for the better. The good folks at Milwaukee now have a 12v heated jacket. I'm going to try it out!
  11. bisco
    52,854
    i'm more concerned for my windscreen than my body.:cool:
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Took an EV trip today, 41 degrees on the temperature guage. With full charge (EV 12.6) my trip odo topped out at 9.2 miles when ICE kicked in. Can't wait for summertime again. But on the plus side, average MPG was 190MPG, not bad. Total miles of trip was 10.6 miles
  13. bisco
    52,854
    guess it's going to be a frustrating winter if we don't concentrate on mpg's instead of mpkw's.:cool:
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    lucky for me I'm only 2.7 miles from work, hopefully the range can give me at least 6 miles, that's all I'm asking.:cry:
    lensovet and John Hatchett like this.
  15. bisco
    52,854
    could be the perfect commute! i may have to plug in at work, i have been spoiled.
  16. John H
    John H Senior Member
    2,208
    558
    The Volt (Ampera) has a 16kWh battery (raw) but the my2012 has 10.4kWh available to the user. The my2013 has a bit more when they introduced a enhancement to the battery chemistry.
  17. bisco
    52,854
    thanks. it makes me wonder if we're comparing apples to apples when changing 16kwh ampera to 2.7kwh prius.
  18. John H
    2,208
    558
    I think PriusKitty has been using the Leaf as a starting point, and adjusting the kWh and curb weight to match the PiP. Someone needs to add the PiP to the inventory of vehicles in the tool.
  19. bisco
    52,854
    agreed. it would be nice if there was a metric conversion for us slow types too.:cool:
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    correct
