EV Range Post Polar Vortex
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by priuskitty, Mar 8, 2014.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Ok Prius Plug Inner's Here's your opportunity to list your EV range increments since the Vortex
    My EV range today is 9.4 miles. Was 9.3 miles during the vortex period. But combining actual EV miles travelled + EV range I got 10.1 miles! My EV range should go up after there is a consistent increase in EV miles travelled due to a warmer battery. I will post often my results this coming spring.
  2. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    Would be good to report the total sum of elevation changes, average speed and distance of your commute. These affect EV distance as much as anything else.
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
    I will just keep it simple.
    Last summers high starting est. EV 18.2, slowly it started to drop in winter to a low of EV 8.7 starting . Our February average temp was 7.7 degrees f. Stayed that way until March 2. Now it has very slowly started to clime, now EV 8.8. The last 2-4 day's temps have started to clime into the 28-32 degree temps for highs, so EV est.should slowly continue to clime. I have been able to get about 10.2 If driving all EV. Winter time most of my trips are short 6-8 miles most drives.
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yeah, sorry, I should have explained my EV travels are either to work (2.7 miles one way) or to Sam's Club (today) driving down the side streets at about 17 to 25 MPH then after about a mile and a half it's 35 MPH the rest of the way. No hills in Clawson, Michigan. And it's usually all EV so if your's is with ICE combo the results won't be that accurate. (not you, retired4999, anybody else who's giving their results here)
    retired4999 likes this.
  5. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I'm up to 14.5 right now. Lows were in the 11's and 12's.
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    And the Polar Vortex affected you how?:whistle:
    chesleyn likes this.
  7. uropip
    uropip Member
    138
    38
    S.E. MASS
    2013 Prius Plug-in
    I got up from 9.0 to 10.1.. Lol
    Galaxy S4 ?
    priuskitty likes this.
  8. saltybp
    saltybp Junior Member
    New Jersey
    I am at 8.6. Last winter it hit 8.8. The high during summer was 12.
  9. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    12.3 in summer, down to 9.1 now.
  10. bisco
    52,767
    i am in florida, i miss my pip.:cry:
  11. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    My low was 11.8
    I get 24.8 daily now.
  12. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    13.3-13.4 pretty regularly since I bought PIP in December, then 13.6 today after two milder days (upper thirties.)
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    The polar vortex affected us by stealing our cold and giving us warmer temps. I also have high 10's for my lows and just hit 14.7. That is the highest EV count I ever had.
    iPhone ?
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yeah......so it was painful for you in California?:whistle:
  15. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    My estimate slipped to a winter (in Minnesota) low of 10.1
    Now that spring has arrived (temps in the 40's), it has already climbed to 12.3
    Hooray!
  16. markabele
    5,084
    1,782
    Nebraska
    Never dropping below 10 during a extra horrid MN winter this year is quite impressive.
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Having a garage helps, mine's outside all winter
    SGH-M919 ? 4
  18. markabele
    5,084
    1,782
    Nebraska
    It definitely helps. What was your lowest this year?
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    SGH-M919 ? 4
  20. john1701a
    12,840
    5,312
    58
    Lost of my parked time and recharging was out in the brutal cold, at work.
    12.4 was this morning's estimate. So, it's still going up.
    20 miles of EV and 15 miles of HV were the results of yesterday's driving. It was just commuting back & forth to work with recharging in between. The average came to 134 MPG for the total 35.5 miles traveled.
