EV range went from 13 to 10 miles in 1 year
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by elmofongo, Mar 7, 2013.
  1. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Ain't regen great?;) I usually have 14+ miles showing on a full charge. If I do some freeway driving it can go up to 15.5 following the next charge. The other day I had 15.1, drove 16.2 miles and had 1.4 EV remaining. The route had speed limits of 45 and 50, with slight hills, and the last mile was on a fwy where I kicked it up to 58 mph. In town I find the EV estimate fairly accurate, and can usually go pretty close to what is shown. I sometimes go a few days of EV only driving, charging each night, surface streets only. Again, there is certainly regen involved. Whether the computer takes that into consideration in tracking my driving history, I have no idea. Being in a warmer part of the country, and always garage-parked, I haven't experienced the low EV estimates others have described. Our winter temps get down into the 30's, but that hasn't had much effect for me.
  2. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)With the temperature in the low sixties this evening, I experienced about a 15% increase in battery life during my 9.8 mile (all EV) commute home. I started off with 9.6 mile range after a full charge. My EV ratio is 59% and HV is 41%. Looking forward to continued warmer weather.
  3. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    My Weekday drive for the last year has been pretty consistant.
    During the Winter my low estimated EV was 9.4.
    Now the last 2 weeks with the warmer weather, I'm up to 10.2.
    As Expected.
  4. lensovet
    2,615
    496
    Burlington, NJ
    Just imagine the threads here if the factory default was 10 miles. Would anyone be writing about how their range went up?
    Ken Blake likes this.
  5. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    That was all "in town", with little or no regen (pulse and glide).
  6. rogerv
    1,639
    317
    I used to be able to pulse and glide easily with my two Gen ll's, but find it extremly hard to hit the sweet spot on the PiP. I'm either using EV or charging. So rather than glide under a light throttle, I am seeing regen charging any time I let up on the pedal or go down even a slight grade. This is in additon to easing up to stop signs and red signals and causing regen that way. If there was no regen, I wouldn't have gone the distance I did and have EV range left over after exceeding the original EV available range, right? Could that be what is happening in your car?
    I just did it again this morning, this time in town with a max speed of around 40 mph. Started with 15.4, drove 12.4 miles and have 3.7 EV remaining. Slightly uphill going out, then slightly downhill on the return, with two stops where I powered down. I live on a hill, and am able to go about a half mile, including a stop sign, without using more than .1 EV, and usually none. Of course, I use more EV coming back up the hill, so everything evens out.
  7. Ken Blake
    351
    180
    Portland, Oregon
    I think you misunderstand how the "EV Range" works. All that number represents is the car's best guesstimate how far you can go on the amount of charge you have left. This is based primarily on driving history. Most of my history with the car has been during colder months, so I expect to continually exceed the estimated EV range as the weather here in Oregon gets warmer and battery efficiency improves, as a result. In the Fall, when temperatures start declining, I will be constantly running out of power before I reach the estimated range number. That's why I suggested on the Future Telematics thread that Toyota make it possible to switch the EV Range number to a battery percentage instead.
  8. rogerv
    1,639
    317
    The driving history period that the car remembers must be fairly short. If I do a few days of in-town EV only driving (or run out of EV and go HV for a short time) mine estimates usually 14+. But throw in a freeway trip and a long downhill run coming back into the valley where I live, and running several miles of EV at freeway speeds, I get as high as 15.5 EV range. It only lasts maybe three or four days of in town driving before it slowly drops down into the 14+ range. Thanks for your explanation.
  9. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Of course we would. We would all be posting our range for top bragging rights. Oh, we already do this:)
    Mike (up to 13.4 miles a few days ago...but back down to 13.0 after a couple of days driving faster on freeway.)
  10. Adam Leibovitch
    498
    102
    Have you tried disconnecting the negative battery terminal for 5 minutes? It should bring you back up to 13
  11. lensovet
    2,615
    496
    Burlington, NJ
    And accomplish absolutely nothing apart from resetting ALL FE data.
  12. lensovet
    2,615
    496
    Burlington, NJ
    Sure but the threads wouldn't be "why the hell does this car get such shitty range and my battery needs replacement after 1 year!!!!"
    3PriusMike likes this.
  13. Adam Leibovitch
    498
    102
    It fixes OP's problem. And it actually just erases the trip A and B as well as Ratio A and B. The monthly consumption record will not be lost, and your radio presets will not change.
  14. lensovet
    2,615
    496
    Burlington, NJ
    how many times do we have to go over this, resetting a meter which is an estimate of your range accomplishes absolutely nothing other than making you lose data
    also i'm not clear on how the radio doesn't lose your presets…does the radio have a battery of its own?
  15. CharlesH
    2,797
    1,163
    Roseville, CA
    Or some flash memory to store settings.
  16. Adam Leibovitch
    498
    102
    Test it out and tell me if your presets get lost.
    And your answer is assuming that the PIP has a perfect battery that is immune of all problems. Eventually someone will have a problem. If you had a bad battery, the reset could help you to see that. And if its something that you are worried about, whether or not YOU say its rational, resetting can help you to calm your nerves.
  17. bisco
    51,944
    how can resetting tell you if your battery is bad?
    lensovet likes this.
  18. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    My estimated EV range did fall from the usual 13.3 miles to about 12.7 miles in December and January. It's been back to 13.3 - 13.5 miles so far this month.
    I routinely (daily) get between 20-22 miles of actual EV use on that estimate. For example, there's a drop in elevation that I can take advantage of, so I EV from home to the freeway and then for the first 3 or so miles on the freeway. (That is, I EV until the range falls to 10.0 miles). That distance is about 6-7 miles. Then I switch to HV for the next 20 miles on the freeway. The last 5 miles of the trip are all EV. I reverse that on the way home. Sometimes I arrive home with a few tenths of a mile left, other times I tap into the 1 mile HV reserve. Either way, I always get more EV range than what the estimate actually says, even though the estimate is almost always in the range above.
  19. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    It's starting to get warm here... finally. My estimate is going up as a result, just like it did last spring.
  20. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    My one way commute to work & back home is 9.8 miles. For the last week or so, when I recharge, it's been showing 9.8 miles available? No more, no less.
