EV range
Discussion in 'Prime Plug-in Charging' started by Jeff Liu, Sep 22, 2017.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    COOOL dual camera system! (y)
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    priuscatprimeguy and Mark57 like this.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    yup, I went out today to see if I had it on, and yup, that's what I got. meanwhile here in Michigan we're in the middle of a winter storm, 9 inches predicted, drove a co-worker home got 12 miles EV when it ran out and ICE took over
    Data Daedalus and bisco like this.
    52,862
    is that mostly highway?
    Data Daedalus likes this.
  5. priuscatprimeguy
    2,730
    2,640
    lol, you're serious? top speed maybe 25 MPH, average speed 5 MPH, and, no, not anywhere near a highway.:p
  6. bisco
    52,862
    it must be the heat pump eating up your ev?
  7. priuscatprimeguy
    2,730
    2,640
    that, and the traction of the tires in the snow covered roads:eek:
  8. bisco
    52,862
    yep, that'll do it.
  9. priuscatprimeguy
    2,730
    2,640
  10. bisco
    52,862
    love your new setup by the way, thanks to john1701!
  11. priuscatprimeguy
    2,730
    2,640
    still trying to figure out Pinnacle 21 (movie software) to put two camera video's one on top of the other. but the video of the snowstorm is from my dashcam, not what @john1701a has.:D
  12. DavidA
    2,349
    1,825
    Chicago western burbs
    Just got 17 miles out of a full charge. :( Teens at night and up to 25 F in the daytime. I've got 3/8 of a tank remaining from August. And I hadn't used a cup of that until now. I don't mind flushing it all out and refreshing with some new gas that I almost might somehow maybe hardly not even use up by the end of winter. :D
    But when the ice is glued onto all the windows, and the inside of the windows are also covered with humidity, and I have to shovel around the car to move it - yes - there's gonna be some HV gas usage. I can handle that for a few months.
  13. Tideland Prius
    16,681
    Wow that's quite a drop. Was the car plugged in prior to departure?
  14. DavidA
    2,349
    1,825
    No. I plug in once every 3-5 days. My commute is 1.5 miles each way. So unless I have an actual errand to run, the short cold commutes and the car sitting in cold soak mode cuts the EV mileage a bit. In this last EV period I had used the heater several times. And it went to ICE with 3.5 miles left at 24 degrees to precondition. I know that's the way it should work, but that does cut the mileage shy of what a warmer day would offer.
    17 is the shortest EV actual I've had yet. Most was 32 miles. Perhaps in the winter I should just convert them to kilometers to make me feel better. 17 = 27.5 :D
  15. priuscatprimeguy
    2,730
    2,640
    in my case, I was plugged in, drove 2.7 miles to work, worked, then drove co-worker home, using up 12 miles of EV before ICE kicked in.
  16. Tideland Prius
    16,681
    Ahh I see. So it's a worst-case scenario - cold soak with no plug. Good to know. Thanks!
    Yes.. 27.5km... excellent. "Now you speak-a my language" :D
    Holy.
  17. priuscatprimeguy
    2,730
    2,640
    and 8 inches of snow, the no salt version:eek:
  18. Tideland Prius
    16,681
    Ok that doesn't count :p
  19. priuscatprimeguy
    2,730
    2,640
    right, right, right, because you're from Canada:p
  20. Tideland Prius
    16,681
    Actually I think you get more snow than I do. But temps are probably the same.
    Curious to see what happens at -40..... just for the heck of it. (Not that I'm wishing that kind of temperature on you)
