Evap Canister Question
Discussion in 'Gen 3 Prius Technical Discussion' started by Rebound, May 9, 2024.
  1. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    This post is about a 2013 Hyundai Santa Fe. But I figure someone here knows the answer.
    My father-in-law couldn’t fuel his Hyundai; the pump would continually click off. I removed the EVAP canister and charcoal poured out of the lines.
    What happened is that the little foam screen that keeps the charcoal from escaping deteriorated. So I was able to pour ALL of the charcoal out of the canister, then I reattached the hoses and put it all back together. The car runs fine and we can add fuel without any difficulty.
    A replacement canister is about $550. Alternately, I can cut the canister open, put a new screen in to keep the charcoal pellets in place, and either put the charcoal back in or fill with fresh charcoal (if I can find any), then glue the canister back together. OR, I can leave it as-is.
    THE QUESTION: (Yes, finally, I’m getting to the question!) Can I cause any damage or harm by just operating the vehicle with no charcoal in the canister? I haven’t smelled any fuel (I tried). The car runs fine. So, can this cause any sort of damage?
  2. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    The car is designed to work with certain equipment. When you remove it, it doesn't
    work the same.
  3. Rebound
    3,996
    2,645
    Portland, OR
    Exactly! I don’t know either, that’s why I’m asking.
  4. Leadfoot J. McCoalroller
    8,293
    7,809
    Pennsylvania
    2018 Prius c
    I did almost exactly this repair on a different Hyundai.
    Instead of opening the canister and installing a new screen, I made my own screen a few inches down the hose, so the charcoal couldn't get very far.
    Worked perfectly for at least 6 months- unknown beyond that due to sale.
    You can use grocery store cooking charcoal- the trick is to get the lump style and break it into smaller pellets.
  5. ChapmanF
    19,060
    I had always believed the stuff in the canisters is activated charcoal.
    There seem to be various processes involving heat or chemicals that 'pop' charcoal like popcorn into a form with a lot more surface area for the same mass. The linked Wikipedia article suggests about a thousand times the surface area of plain charcoal. (!)
    But the top "shopping" links in my Google search for activated charcoal are showing, like, 50 pound bags for $9.20. Doesn't seem hard to get the stuff.
  6. Rebound
    3,996
    2,645
    Portland, OR
    Latest I’ve heard is that you can buy the stuff at Petco — it’s used in aquarium filters.
  7. Mendel Leisk
    42,379
    Or just reuse the old. I know though: good opportunity to refresh it, if you can get the right stuff.
