Evap cleaning gone wrong!!
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Jingbobby, May 31, 2025.
  1. Jingbobby
    Jingbobby Junior Member
    Louisiana
    2018 Prius Prime
    Hey guys - I need some serious help! After I used the ac evap cleaning (injecting foam into the ac drain line) my car is giving me a “hybrid system malfunction” warning. My cruise control and 3 buttons to drive mode, ev/hybrid and EV auto stopped working while I’m driving..
    It does work for a brief moment right when I start up my car.. before the hybrid system malfunction message comes on. Anyone ran into this before? Any help is appreciated!
  2. DOHCtor
    DOHCtor Active Member
    170
    102
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Well, the battery is cooled by the A/C on those cars. I can't imagine what happened.. Do you still have some cold air blowing? If there is a Hybrid Battery Malfunction indication, there is a CEL code stored in the ECU. Have you checked it?
    Bastrop likes this.
  3. Mendel Leisk
    42,195
    This is a 5th gen, or the 2018 per your avatar?
  4. Trollbait
    12,789
    If 2018, perhaps something got knocked loose while doing the cleaning, or the cleaner got somewhere it shouldn't have. Could also be unrelated to the cleaning.
  5. DOHCtor
    170
    102
    2024 Prius Prime
    SE
    Can't imagine a A/C issue causing a Hybrid fault on a 2017/2022... 2023+ however.. as always, i can be wrong! Definitely want to know what happened however..
