Evaporative System State: "incomplete"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by whburling, Jun 5, 2018.
  1. whburling
    whburling Junior Member
    53
    17
    Gales Ferry, Ct
    I am using Techstream 12.00.127 and my car is a 2006 Prius.
    I am attempting to evaluate if my car will pass emissions.
    Somehow I got to a screen that included a menu item on the left screen side which contained an option, "Monitor". . I left clicked on "monitor" which pulled up a screen that appeared to reveal emission status.
    Catalyst Efficiency indicated "complete" and "Pass"
    O2 sensor indicated "complete" and "pass"
    BUT
    Evaporative System indicated "incomplete" and "Pass"
    Can I ask Techstream why iEvaporative System may be incomplete and for data that might shed some light on why it passed but is not complete?
    Will the above states allow the car to pass an emissions test?
    Thank you
    bil
  2. JC91006
    16,748
    8,553
    If you've disconnected the 12v battery recently, it would show "incomplete" until you've driven many miles to let the computer pick up the status again. I would think you would need to drive about 100 miles.
    Here in CA, to pass an emissions test only requires that no warning lights are "ON" on your dash displays.
    Raytheeagle likes this.
  3. whburling
    53
    17
    Gales Ferry, Ct
    Thank hyou for replying. Much appreciated. Especially knowing it will take about 100 miles. Thank you
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    I had to get a smog check in December and I just completed a brake inspection, which had te 12 volt off:).
    I passed the inspection with no issues;).
    Good luck and keep us posted (y).
