evct transmission noise
Discussion in 'Prius c Technical Discussion' started by xerox6135, Jul 25, 2013.
  1. xerox6135
    xerox6135 Member
    170
    93
    michigan
    My Prius c has always made a high speed whirling noise when braking but now at speeds of 42 to 46 MPH this high speed whirling noise is there and when you are just coasting anybody else have a noisy transmission or is this something I should be getting to the dealer with
  2. maddog61
    maddog61 Junior Member
    44
    sounds like the regenerative braking... never noticed transmission noise....
    49,489
    best thing to do is take a drive with the service manager. if he thinks it's normal, drive a new one to see if it makes the same noise. these cars aren't silent, so, it's hard to say what's normal and what isn't without a comparison.
  4. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
  5. mahout
    mahout Active Member
    655
    116
    NC
    There's only 2 c's here and neither exhibited the noise you describe. Make sure you document the call to your dealer by getting a copy of the shop report and make sure the sound is well descibed. Additionally, it wouldn't hurt to strap a tape recorder to the transmission and document the sounds there as well. Resting on the tranny will pick up sounds you don't hear in the drivers seat but which are important to the investtgatuing engineer.
    good luck.
    PS your description sounds like a rough place on one of the cones.
  6. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Cones?
  7. ChinchillaGirl
    ChinchillaGirl OrcaCar
    157
    72
    SJ/SC Commuter
    I've had a similar experience while decelerating from about 65to 45 - coasting, no brakes. Sounds a little like howling zombies, or a decelerating spaceship, I can't make up my mind. And, I notice it also only happens when outside temps are over about 80F. Heat shields?
  8. type17volkswagen
    type17volkswagen Junior Member
    66
    16
    Northern Virginia
    Mine does this (or something similar-sounding) too at around the same speed. To me, it sounds enough like the usual regen sound only faster and louder.
