Even in the cold winter, i brok 50mpg again.
Discussion in 'Gen 3 Prius Fuel Economy' started by adamace1, Jan 21, 2010.
  1. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Tom183, you should reverse upper & lower blocking for your gen3 versus the gen2 of some in this thread. The inverter is at the upper grill of gen3 instead of lower as in the gen2. Inverter needs to be cooled, and we have no way to measure its temperature at this point. There is a nice table in a recent 2010 blocking thread correlating blocking %'s upper/lower to ambient.
    For a highway trip like that, leave upper grill open and block the lower. But you won't save anything except in the warmup phases because at highway speed, the ICE is wasting heat anyway, just to produce the required HP. With my short drives, I can block year round. When I do take a summer highway trip, must unblock. But for 3 seasons, the fan can take care of it without removing the blocking. So lower block in 20s will be fine, so long as the system is working (thermostat opens, e.g.). Much colder than 20s, and the upper blocking would not concern me either.
  2. Tom183
    Tom183 New Member
    652
    65
    Maine
    I'm not sure how true that is with the Gen III - and I wonder if the inverters actually might be happier with a little heat (relatively speaking).
    I guess we have to wait for the codes...
  3. odaigle
    odaigle New Member
    35
    Canada -- Montreal
    I noticed a huge difference in the fuel consumption between setting the heating at 21°C/70°F and 23°C/73°F in cold (air temperature < -5°C/23°F) conditions. I feel this is related to the state of operation of the hybrid system that changes at a coolant temperature of 70°F. Higher than 70°F, the ICE is allowed to stop when the car is stopped. When 23°C/73°F are requested, the car has to keep the ICE running to reach a coolant temperature >73°F. However, when 21°C/70°F is requested, the car can stop the ICE as soon as the coolant temperature reaches 70°F.
    Am I the only who have experienced this?
  4. Tideland Prius
    16,559
    No idea but I do noticed that it's significantly warmer at 25°C lol. So 23°C must be a good median.
    I'm now up to 4.4L/100km thanks to colder temps and shorter trips =(
  5. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Now that you guys took over the thread with your grill blocking.. I'm just wondering if you guys would post your real mpg?? I'm getting 52.2 average over all the miles. How much more are you guys getting than me? Also It's pretty hilly here, so i don't have flat ground helping me at all.
  6. ksstathead
    1,244
    245
    Kansas
    Tank before last, all very short cold start driving, 40 mpg.
    Last tank, all freeway/backroads, 56.5 mpg.
    Both of these are calculated, and roughly 5% worse than displayed.
    Have not tallied all of my tanks yet, but it is pretty bad due to short short (1.5mi) commute and cold weather.
  7. SpartanScott
    SpartanScott Michigan Member
    60
    Howell, Michigan
    I'm at 52.4 MPG per MFD. Hand calc gives me 51.82 MPG. 56000 miles total over 2yrs 10months. ~70% highway.
  8. adamace1
    1,403
    193
    Charlotte, NC
    And you do grill blocking? Also I spent the first 30 years of my life in MI so i do know you have alot more cold to deal with.
  9. SpartanScott
    60
    Howell, Michigan
    Correct, I grill block in Winter as needed. Other factors effecting my lifetime MPG are I spent 7 months living in the CA bay area (~60 MPG avg), and I tow a trailer or jet ski (~1200 lbs) many miles in the summer (~44 MPG avg).
  10. odaigle
    odaigle New Member
    35
    Canada -- Montreal
    I managed to get 47 MPG (calculated) at 30% town 70% highway (68 MPH) below -10°C (14 F) with winter tires (40-38 psi) and 100% lower grill block, 0% higher grill block. Now, I have blocked 75% higher as well and I am at about 55 MPG (MFD, not yet calculated, but should be around 52). The temperature has risen though. About -5°C (23F). I don't have a Scangauge and I am too chicken to block 100% higher. If temperatures goes below -20°C, I will probably try it. But -5°C - -10°C is too warm to try it.
    I have never used this car in summer conditions, and I have put the winter tires 10 km away from the dealer. I bought it late November. I am pretty curious to know what will be the FC during summer, with the low rolling resistance summer tires...
