Every used car I have bought has a headlight problem '04
Discussion in 'Gen 2 Prius Main Forum' started by terramir, Oct 6, 2016.
  1. terramir
    terramir Member
    305
    47
    Los Angeles
    ok, now that my battery is halfways sound time to get to work on other things
    my prius has halogens, although I got the foglight switch, and this thing is otherwise fully loaded.
    i.e. side air bags, Nav
    grill and fog lights are missing whoever fixed up the prius after it was salvaged cheaped out.
    so instead of hid it has halogens. poorly aimed to boot there are two dots on the road about 12 ft in front of me. and well forget seeing potholes, shit if I wasn't driving on LA freeways I'd be in trouble.
    is there anyway to retrofit these with LED's and a level sensor i.e auto aiming very bright LED's dun wanna blind anyone ;-)? preferably cheap, I dun mind doing the work myself.
    terramir
  2. JC91006
    16,480
    8,397
    Just clean the headlights. Halogen was probably standard equipment on the car, not hid
  3. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Just check that bulbs are installed correctly. Or better than that install good bulbs. Then aim the headlights correctly.
  4. jeff652
    jeff652 Senior Member
    606
    623
    Idaho
    Yup, follow the headlight housing adjustment procedure & polish them and you should be fine. Then decide if you want to add HIDs or not.
  5. Pubrica
    Pubrica Junior Member
    South Torrance, CA
    Additionaly, every connection mast have good contact which means spring on back of bulb(HID) etc. Make more pressure on spring with bending little bit when R/R of them. This way secure bulb more than before(prevent vibration). hope this helps
