Everyone says don't buy an old Prius!?
Discussion in 'Newbie Forum' started by JamesAdams1, Sep 16, 2017.
  1. valsor
    valsor Junior Member
    Bellevue WA
    Buying an old Prius is no longer an issue since there are so many newer Priuses now sold at almost the same price as the old ones.
    douglasjre likes this.
  2. ChapmanF
    18,236
    The last time I bought a vehicle that wasn't an old Prius was in 1996.
    Moving Right Along likes this.
  3. Shelby profita
    Shelby profita Junior Member
    37
    Phoenix, AZ
    Found a 2010 with afresh water pump 8k miles ago and has 231k miles on it currently, but I know to stay away from 2010 as the piston rings wear prematurely....still concidering it but otherwise for the same price of 3500 going to get an 07 with 255k as 06-09 are very good years
    Data Daedalus likes this.
  4. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    I would get the 2010. You can get a JDM engine for 1200 and put it in if you need it
  5. rondefly
    rondefly Junior Member
    South Lake Tahoe, CA
    I have the same, My 2005 is still good at 250000, just taking the big battery out to replace some bad cells, I've done this once before. takes a few hours and is not that hard of a job. The hardest part for me at 83 is lifting the battery out of the car to a bench. Just bought an 83 with 108000 miles on it and am pleased with it also. Thanks Ron Triano
  6. Mendel Leisk
    41,485
    Wow, all the more power to you. (y)
    Montgomery, C Wagner and George W like this.
  7. C Wagner
    C Wagner Member
    183
    60
    Boston
    The hv battery can be rebuilt or you can switch in a rebuilt one for $600-2000
  8. C Wagner
    C Wagner Member
    183
    60
    Boston
    Thats not really that bad. Try owning a regular car 165k.
  9. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Rondefly is most definitely a seasoned stud!
  10. douglasjre
    2,181
    720
    Null, NL
    The antenna amp and the JBL system are the only things that I agree sometimes happen. The rest of those things on your list make no sense. Who's telling you you needed all that? Me and my friends have a total of 17 Priuses. None of them have ever needed wheel bearings and some of the cars get up to 270, 000mi. First brake job is usually needed around 200,000 mi. Traction battery: why did your traction battery go bad so early? Are you deep cycling it every morning or in the car wash? This is just the oddest list of repairs... Most of all 3 12V Optimas? Who's leaving all the lights on in the car overnight? This repair list makes no sense
  11. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    I had to have front wheel bearings done on my 2009. Our roads in PA are terrible. As they say, YMMV (your mileage may vary, along with everything else).
    C Wagner likes this.
  12. C Wagner
    C Wagner Member
    183
    60
    Boston
    Bearings are little packs with metal balls and lubricant in them. They will certainly wear in a prius just like in other cars. I've had bearings go in cars at seemingly random intervals, even with no abuse, no sea salt in the air etc. 12v AGM batteries likewise have a lifetime, even if properly constantly lightly charged and maintained. Most older Prius owners are worried about or are getting to HV battery failure in the high 100Ks or low 200Ks, I'd bet. A car is a small metal home that is exposed to a huge amount of rolling, shaking, banging, torquing. Things wear out and are changed.
    What's great about the Gen 2 cars (that's what I took ownership of last November) is that everything is so well documented on PriusChat and other websites. A used engine, if your high mileage vehicle's oil consumption can't be solved on PChat) is as little as $1,000 installed -- the price I paid for the rear struts to be replaced. People warn you about most of the trouble areas. And the things your mechanic can't do, you can sometimes do with a bit of prep and work (the HV battery rebuilt, or sourcing).
  13. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    I agree...unless you're a good mechanic or an exceptional DIY'er, avoid Gen 1's and 2's. This is a generality, of course. Some Gen 1's and 2's are, still, out there and were well cared for and would be a good buy BUT, say, buying one off of Carmax without any history available? Not a smart move. I can't people actually buy a car on-line or via an app without actually looking at it and checking it out.
  14. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Those are the ones who buy a house unseen so the have a garage for their vehicle!
  15. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Well, I finally traded in my 2009 Gen II at about 165K. It was a magnificent machine, although showing its age. Moved up to a new to me 2024 Gen 5 Prime with 3K on it. May it do at least as well as its predecessor!
  16. bisco
    51,969
    congrats, all the best!
    ILuvMyPriusToo likes this.
  17. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    See you in the Gen 5 forum, @bisco ! :)
  18. Duddy03
    Duddy03 Junior Member
    22
    Crossville, TN
    2018 Prius Prime
    I have a 2004 Prius with 265,000 miles. It still gets 50 mpg. Issues: Main battery will need to be replaced at some point (replacement costs have dropped); the rear hatch mechanism is prone to failure; the water pump had to be replaced. A solenoid to the key fob has failed (I simply use the smart fob to start the car). A headlight sometimes turns off at night (turning the lights on and off restores both lamps). I do my own oil changes with Amsoil synthetic. Car care is easy and inexpensive. I expect it will go well over 300K. My other car is a 2018 Prius Prime. Questions?
  19. bisco
    51,969
    what does a new battery cost these days?
