"EVSE Upgrade" upgrade charges in 2 hours on 120v.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by DadofHedgehog, Oct 9, 2012.
  1. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    Folks,
    I am getting a secondary meter installed to gain ToU night rates for the PiP and future electric cars (see "Free Electricity in Virginia" thread for details"). hence, for the 1st time since April when I purchased the PiP, I am charging every night on the OEM EVSE from a 120v line, until the utility plops in the new promised secondary meter. With the electrical work to add a 2d meter base and the inspections and now waiting for the final utility action, my Level 2 charger has been out of order for just over a week.
    Punchline: My EVSE Upgrade - upgraded OEM EVSE now charges routinely in 2 hours whereas the pre-upgrade OEM EVSE routinely took three hours to charge during a multi-state PiP trip last May & June. I got it pEEf-upgraded this August but never got around to testing it until now, as the L2 charger is so much easier.
    How do I know the charging times: Entune "Start" and "Completion" e-mail notifications. For the Level 2 charging, they were routinely 80 - 90 minutes apart. Now they're 120 - 130 minutes apart.
    I know I am using a 120v line in the basement via a window, because I installed said line myself some years ago.
    I run the traction battery down during my commutes and errands to as low as it will go - that's the point of PiPping, right?
    So - anyone else with an EVSE upgraded by pEEf have a similar result?
  2. John H
    John H Senior Member
    2,208
    558
    The EVSE advertises it's max amperage to the vehicle when you plug it in. I always assumed that the EVSE that came with the PiP was matched to the PiP but maybe it is not and only provides 11 amps. The EVSE upgraded by pEEf may advertise 12 or 13 amps and result in faster charging.
    Another possibility is that your home's circuit is a 20 amp circuit and the new EVSE is advertising as much as 16 amps.
    The EVSE that came with 2012 Volts has a setting on it. 6 amps, 8 amps, and 12 amps, in case you have to plug into an old electrical system or a shared circuit.
  3. DadofHedgehog
    681
    281
    northern Virginia
    John, I appreciate the info.
    I do understand that the PiP internal charger will regulate the incoming charge so that only 12 amps can come in, hence pEEf's Rev2 upgrade option to 16 Amps is useless for the PiP owners (I got Rev1 for 12 amps). However, your point that my OEM EVSE perhaps wasn't allowing all 12 amps through in its original state might account for the 1/3 quicker charging time. No way to test that theory now because of the EVSE upgrade.
    In any case, I'd love to hear from fellow EVSE Upgraders to see whether their experience matches mine. If so, then pEEf's EVSE Upgrade would be even more worth it than advertised, especially for those without a home Level 2 charger.
  4. John H
    2,208
    558
    mitch672 might know what is going on.
  5. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    Did someone summon me? :)
    The onboard charger built into the PiP appears to be limited to roughly 2.2KW (based on what's displayed on the ChargePoint network display, 2.236 of course that was likely at 208VAC), which divided by 240V comes out to about 9AMPs at 240Volts. Therefore, anything greater than the 12A evseupgrade is not going to charge the PiP any faster, as the internal charger can't take advtange of the additonal power, even if availble.
    cwerdna likes this.
  6. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I'm a little confused here. Is the issue that the upgraded OEM EVSE is taking 2 hours at 120V, which would be a nice improvement? Or that it's taking 2 hours at 240V, which is a problem, since it should cut the time in half to 1.5 hours. It's not clear.
    The OEM EVSE has no way of knowing whether it's plugged into a 120V 20A or 15A capable circuit.
  7. DadofHedgehog
    681
    281
    northern Virginia
    The post-"EVSE Upgrade" Toyota EVSE is taking about 2 hours (2 hours 1 minute early this morning) to charge the PiP off a 120v line, whereas before pEEf's upgrade it took 3 hours.
    No complaining at all :) - just a pleasant surprise and I wanted to compare notes with other pEEf EVSE Upgradees out there to see how they are doing on time.
    Reason Level 2 charging came into the discussion: I normally charge at level 2 at home, and because of a utility meter upgrade the L2 charger is temporarily inop, hence I'm back to using the Toyota EVSE and noticed the 1/3 quicker charging as a result.
  8. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I'm also a bit confused. I did the EVSE upgrade. My home plug is a 240 outside. Takes roughly 1.8 hours.
    If I'm in a hurry, I rarely wait for that last 20 or 30 minutes of trickle charge. It does a great job at filling up the battery fast.
    At work we have old paddle chargers, but they added 120v plugs to the side of them so we can use our personal EVSE's to plug in. That takes 3 hours.. or so I assumed.
  9. bisco
    49,813
    i thought the upgrade was supposed to reduce charging time to 1.5 hours on 240v? as far as reducing it to 2 hours on 120v as op suggests, i would like to know how that is possible?
  10. chesleyn
    596
    158
    Los Angeles
    I will time it one day and see. As I have a base model I will have to go outside and look at the light on the charge inlet to time how long it is illuminated. The car says 1.8 hours when the battery is at about 23% soc (HV mode). It also says it's pulling down 1.9kw
  11. John H
    2,208
    558
    Another possibility, pure speculation, is that your 3 hour charge times on the roadtrip were at a lower voltage than you have at your home. Your observations during your roadtrip may have been at 105V while you home charging at night might be getting a full 120V or more.
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I don't completely understand what this thread is about but my charging situation at my apartment is my voltage at my outlet is 104 volts and with .1 miles left in EV my charge time is 2 hours and 34 minutes.
  13. bisco
    49,813
    104 volts? are you in a third world country?:confused:
  14. John H
    2,208
    558
    Be Nice!
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    parking lot lights on same circuit:cry:
  16. bisco
    49,813
    amazing it only takes you that long to charge, mine takes around the same time @ 120v.
  17. John H
    2,208
    558
    what triggers the PiP to finish charging at the lower amperage toward the end of a charging session? Is it triggered by battery temperature, a timer, state of charge, ???
    That could be the reason for different charge time experiences.
    The Volt kicks in a thermal management system, if needed, to keep the battery within temperature range rather than ramping down the amperage and slowing down the charge rate.
  18. CharlesH
    2,787
    1,153
    Roseville, CA
    The optimal charging pattern for Lithium Ion batteries is complicated. Do it wrong, and you can get an explosion. Even the charger in your cell phone has to modulate the charging rate in a non-trivial way. I would think that all of the mentioned factors come into play.
  19. it's not unusual for the voltage to vary a lot. From 100 V to 130 V, especially older buildings. The casino, near us only reads 107 V.
  20. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    'Just received my EVSE upgrade. I see no change in charging time on 120v, and about 1.5 hours charging on 240v. I've charged at several different locations with slightly varying voltages and the charging times are quite similar. 'Nice upgrade, and the optional 110v plug converter is a worthwhile add-on.
    cwerdna and lensovet like this.
