Exasperating misinformation on 12V battery
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by frederw1701, Jan 16, 2025.
  1. frederw1701
    frederw1701 Junior Member
    50
    16
    WA
    2018 Prius Prime
    2018 Prime.
    I Googled because it was such a simple question and even asked a battery store, showing them a picture of the battery.
    Putting them all together, I have been told that the 2018 Prime battery is in the trunk, that it is AGM, that the computer will refuse to charge a flooded battery, and that it's sealed and the caps are not removable.
    Someone on Reddit took a screwdriver to the caps and found liquid underneath.
    Toyota's manual only tells me that batteries are hazardous. Good information but not news.
    So --
    It's flooded, right?
    I can check the electrolyte?
    I should check the electrolyte?
    There's a tool less likely to damage the caps than a screwdriver?
    What exactly is it called or can I have a link?
    51,965
    you could check it, but most people don't. there are some threads here if you can find them.
    also on replacement size and available options.
  3. frederw1701
    50
    16
    WA
    2018 Prius Prime
    Given that it's six years old I feel like putting more than usual care into it to postpone the expense of a new one. Plus I'm so old I remember when that was just one of the things you did, like reading the spark plugs.
    Do I understand right that the cell by cell information from electrolyte density has some advantages over just measuring the battery voltage?
    51,965
    i don't know much about 12 volt batteries. i do know you can get a free load test at most auto parts stores, or even turning on all the electricals and watching the voltage decrease over time, if you understand what's healthy and what isn't.
    i'm old enough to remember checking electrolyte levels on a regular basis. but these days, i'm comfortable caring for the 12v as best i can and replacing when necessary.
  5. BiomedO1
    BiomedO1 Senior Member
    3,639
    1,879
    SacTown, Ca
    It's flooded, right? Yes
    I can check the electrolyte? Yes
    I should check the electrolyte? Yes
    There's a tool less likely to damage the caps than a screwdriver? Use a nickle or quarter, if you need to get a better grip
    What exactly is it called or can I have a link? Huh??? fill with distilled water to the internal line
    You stated the battery was at 12.5 vdc, so I believe it's in good shape and should last a good long while - if properly maintained...
    FWIW; all gen4 batteries are under the hood - all other Prius are in the trunk or under the seat; past and present.
    #5 BiomedO1, Jan 16, 2025
    Mendel Leisk and frederw1701 like this.
  6. frederw1701
    50
    16
    WA
    2018 Prius Prime
    star
  7. frederw1701
    50
    16
    WA
    2018 Prius Prime
    Thank you for the very informative reply.
    As to the "Huh??", if quarters work well and everyone uses them, there won't be a special tool to ask about or shop for, so the question goes away.
    May it last a long time.
    vvillovv likes this.
  8. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    Love the title of this thread. If removing just the 12v battery from the title, the rest of the title could probably fit in 50% of the posted threads in this forum. :D
    Prodigyplace likes this.
  9. Prodigyplace
    12,567
    11,781
    Central Virginia
    The battery model number (345LN1-MF), you would see the MF designation is "maintenance free" flooded battery. It is similar to one in my 2025 Camry. You should be able to use either a regular flooded battery or a maintenance-free battery. AGM does have a different charging profile.
  10. Trollbait
    12,543
    The battery should be fully charged when checking the fluid and adding water.
  11. Robert vickroy
    Robert vickroy Junior Member
    Houston
    2018 Prius Prime
  12. Robert vickroy
    Houston
    2018 Prius Prime
    What you need to know about 12v ICE (Internal combustion engine) in front end of Prius Prime is doesn't talk to the back-end of the Prius when traction battery gets charged.
    It's a stupid story, but I had a 100k warranty so when battery died it replaced them because Dealer Technicians kept saying the car had a problem. They replaced the ICE every 18 months when they died - for 5 yrs, and they kept diagnosing the car and kept saying the car had a problem and I took them at their word.
    After warranty ran out I finally gave it some thought and charged it myself, not having seen all the PriusChat articles saying to do it.
    You have to put a volt meter on it once in awhile and manually charge it or it will come up with a Bad cell and leave you stranded. Or put a solar panel on dashboard hooked to battery directly, or waste the gas and put the car in CHARGE Mode on purpose periodically because that's the only time the car itself will charge the ICE battery-but you still have to test it to make sure your staying ahead of the problem.
  13. Prodigyplace
    12,567
    11,781
    Central Virginia
    i assume you mean the 12v battery, not the (ICE - Internal Combustion Engine) engine (!)
  14. Mendel Leisk
    41,479
    For checking the electrolyte level on a flooded-acid battery, I've found the only way to see the level clearly is to haul it out of the car, set on a bench and put a light behind it. This is something I'd "sometimes" get around to, about halfway through it's lifetime. Clean off the case, the posts, the inside of the cable clamps, and blow the dust out of where it resided as well.
    No clue. In addition to simple battery tests, I'm using a Solar BA5 battery tester* from time to time. It's a new generation electronic load tester, also gives a rudimentary verdict on it's condition. Current iteration is BA9 I think.
    Google results said that, or was that bit hyperbole? ;)
    * There's more info on that tester, in the battery testing link in my signature. (If you're on a phone, hold it landscape-oriented, to see signatures.)
    #14 Mendel Leisk, Mar 23, 2025
  15. ChapmanF
    18,222
    In most flooded batteries I've looked at, each filler 'well' has a neck that reaches down into the cell to the level where the electrolyte should be, and the bottom of the neck has a couple notches so it isn't a continuous edge all around.
    When the electrolyte reaches the right level and touches the bottom of the neck, surface tension pulls the liquid into a kind of eye-shape (with the corners at the notches where it isn't touching) that you notice right away in how it reflects light.
  16. BiomedO1
    3,639
    1,879
    SacTown, Ca
  17. Mr.Vanvandenburg
    1,353
    571
    2020 Prius Prime
    Putting the car in park at stop lights etc or in the driveway in ready mode charges the 12 volt. Engine off. Get a battery monitor.
  18. Prodigyplace
    12,567
    11,781
    Central Virginia
    If they knew the car had a problem, why did they not try to fix it? Was it cheaper for them to keep replacing the battery? Ideally you should have pressed for a repair and, if a Toyota extended warranty, call Toyota to get involved if they did not fix the underlying issue. It is too late for you now, though.
  19. BiomedO1
    3,639
    1,879
    SacTown, Ca
    It's more profitable to keep you coming back for more, by managing the symptoms than fixing the root cause.
    IMHO; They were 'milking' the extended warranty insurance company.
  20. Prodigyplace
    12,567
    11,781
    Central Virginia
    In hindsight, ideally the customer would have realized they would be left with the problem after expiry.
