Excellent MPG even w/ winter gas - why I love this car
Discussion in 'Gen 2 Prius Fuel Economy' started by F8L, Jan 27, 2012.
  1. paycee
    paycee Junior Member
    48
    Wow, is that 59 MPG for Gen II or Gen III? I couldnt even get past 50's =)
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It's a GenII.
    I don't normally get 60mpg tanks due to my commute which is comprised of 98% freeway driving at 60mpg-65mph and a steep section of road with a total of 1,200ft. elevation gain. If I could stay on flat roads 60mpg would be easy enough with a fair bit of gliding when possible. If I just drove it without thinking about efficiency I would be in the 52-55mpg range for each tank. This is with warmer temps usually associated with spring through early fall.
    51,972
    after 8 years, i'm still trying to figure the terminology myself. but i know what you mean. that's amazing, i don't know if there's any place around this busy burg where i could try that. unused landing strip maybe.:rolleyes:
  4. paycee
    48
    so F8L do u mean that you can get better MPG's on highway than city driving?
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Depending on the conditions yes. In heavy traffic city driving conditions ith lots of stoplights it can be difficult to get great mpg. The constant stopping and accelerating is not conducive to efficiency. I have observed that traffic conditions in say Sacramento where everyone floors it from a light then slams on the brakes and cut you off whenever possible, makes it difficult to judge traffic conditions and leave enough space to glide. In contrast the traffic in Davis is light, people drive fairly slow and predictably and the lights don't change constantly which means you have a good shot and not having to stop for every single one. There are also long stretches of road between lights which makes for great gliding opportunity. So in some cities I can get much better mpg than I can on the freeway and in other cities my mpg may go down compared to the highway.
    Highway mpg is less variable and you can generally achieve very good mpg as long as you keep your speeds low. You can further enhance highway mpg by using warp stealth mode when exiting the freeway (long onramps) or on hills and tall overpasses. The reason why a lot of people may get poor highway mpg is because they are speeding at 70mph+, windy or wet conditions, or they are driving aggressively with repeated speed ups and slow downs.
    Without using any hypermiling techniques and despite the EPA 45mpg rating one can easily achieve 50mpg+ on the highway as long as they keep their speed at 65mph or below. This is assuming they are using OEM or other LRR tires and weather conditions are fair. Wind and rain can really tank your mpg.
  6. itsnicetobe
    itsnicetobe Junior Member
    42
    PA
    Great picture ! ! !
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Same trip but less traffic and I got off the freeway a few miles early to avoid the bad section of freeway that always drops my mpg.
  8. bisco
    51,972
    wow! i'm down to 56 mpg's on winter gas, (and winter itself) :) although, this is the mildest winter i can remember in a while.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You have real winters and you average 56mpg in the winter whereas I only average 50-52mpg. Overall you always have better mpg numbers than I do. This is just a fun test to see what I can get on my evening commute. I'm scared to see what the morning commute looks like. :(
  10. bisco
    51,972
    i'm starting to like this warmer winter weather, but when i see you sitting on the ground, all i can think of is a scorpion going up my pantleg.:eek:
  11. bisco
    51,972
    i also drive like an old lady, got the speed bug out of my system 40 years ago.;)
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I stepped on a snake yesterday. It then twisted over my shoe and looked like it was going to go up my pant leg. I screamed like a little girl in front of my two new interns. Girls of course. lol
  13. bisco
    51,972
    :eek: although i live in the 'country', i must be a city boy. when i see a snake, i go the other way.:p
  14. fuzzy1
    10,469
    If it was rattling, then I'd say your scream was understandable. If it wasn't rattling, then I must ask how the poor little innocent snake came out of this encounter. Was it hurt?
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    bisco, I generally do the same. :)
    Fuzzy, the snake slithered away seemingly unharmed. Given the short grass and spongy ground I don't think I put enough pressure on it to cause damage.
  16. dstrauss
    dstrauss 2018 Honda Clarity PHEV Touring
    Midland, TX
    So, is this what it takes to get these unbelievable (50+) mileage numbers...a constant game of driving techniques and sub-speed limit travel? What should you consider realistic mileage if you just "drive it like a car" most of the time? Out here, all of the highways are set at 75mph, and driving 65mph is likely to get you killed. I got 44.7mpg on a 125 mile roundtrip at 75, which seems pretty great to me (my wife's Hyundai Veracruz is having a great day at 24mpg on same route).
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The GenII is only rated 45mpg highway so you're doing pretty good. When I drive to LA I usually maintain speeds between 75mph-85mph. During that 5+hr trip at those speeds I usually end up around 42-44mpg.
    During my normal commute I will average about 50mpg if I don't really try but it can drop into the high 40s if I start flooring it everywhere and stick to 70-75mph on the freeway. The 1,200ft. Elevation change hurts me a bit too.
    My mpg is not really remarkable. It's the guys averaging 60-70mpg over the lifetime of their car that are the lucky/skilled ones. :)
  18. bisco
    51,972
    i'd expect 50-100% better than a similar sized car. what does a camry/accord get at 75mph?
  19. fuzzy1
    10,469
    "Just drive it like a car" varies drastically among different drivers and different regional driving cultures.
  20. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah around 45 MPG, that's a decent result for 75MPH.
    There's quite a bit of legitimate variation in what MPG people are getting from their Prius, and local traffic conditions and speed limits plays a big part in that variation. The other big factor is weather conditions and the amount of heat/AC needed, along with the type of tires needed for those conditions.
    The majority of people however seem to get somewhere between 40 and 60 MPG. Personally I get about 56 MPG, probably because speed limits are a bit lower here, with most of the semi-rural roads I travel being around 50 to 65 MPH. My wife gets about 53 MPG on the same routes, and she basically drives the Prius exactly the same way as she'd drive any other car.
    You might be interested in looking at this survey: http://priuschat.com/forums/gen-ii-...oll-what-mpg-you-getting-in-your-gen-2-a.html As you can see, 45 to 50 MPG is the most common group, but the 50 to 55 MPG group comes a close second.
