excessive blow by, + head gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by freshedie92, Oct 26, 2018.
  1. Mendel Leisk
    42,237
    Still, I wonder about the piston revision. To follow the TSB to the letter you replace them also. And check the crankshaft with plastigauge.
    What might the piston revision be? Even if the rings are compatible, the new piston must be advantageous in some way.
    I appreciate the piston replacement is significantly more expensive, and more difficult. The TSB suggests a machine shop for separating the pistons, installing the new.
    And for all of this, 16.6 hours, IIRC...
    #21 Mendel Leisk, Oct 30, 2018
    freshedie92 likes this.
  2. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    If i had to do it again. I would buy a 4th gen motor and put it in. Same price as a 3rd gen with realllllly low miles. Like this one I found on eBay. 16000 miles(y)(y)(y)
    scona, freshedie92 and mjoo like this.
  3. freshedie92
    freshedie92 Member
    73
    37
    San Bernardino, California
    Too late now, I'm crank deep in this bad boy.
  4. freshedie92
    freshedie92 Member
    73
    37
    I agree that there's some benefit. But not 200rs worth for me. I'm following danlatus steps, and hoping my first rebuild goes as well as his
    Raytheeagle and Mendel Leisk like this.
