Excessive oil consumption: Does using thicker oil help?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Jan 9, 2019.
  1. Preeeus
    Preeeus Member
    258
    60
    Are oil catch cans illegal somewhere?
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Oh yeah it is...
  3. orenji
    orenji Senior Member
    5,887
    3,490
    If it's California everything is banned!
    #83 orenji, Jan 31, 2019
    Merkey likes this.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Yep, that's one of the state that says no to oil catch can. We want your cars to break down asap so you can buy expensive cars much as possible. Engine life and value don't matta in CA.
    orenji and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    You just need to find the right shop :).
    I know of a good one in San Ramon that’s up for the task(y).
  6. Preeeus
    Preeeus Member
    258
    60
    Why are oil catch cans banned in some areas? What's the harm of them?
  7. Leadfoot J. McCoalroller
    8,293
    7,810
    Pennsylvania
    2018 Prius c
    No harm, as long as you eat everything you catch.
    Robert Holt, Preeeus and mjoo like this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Beginners like me who will botch the oil catch can mod can cause pollution from engine release into the air, so it's best nothing happens to an EGR path, that's what California politicians believe.
    Preeeus likes this.
  9. Preeeus
    Preeeus Member
    258
    60
    Interesting. In California, can you still pass smog if there is an oil catch can installed?
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    No, they do a visual inspection of the vehicle. Any aftermarket modifications found would be a failure to pass.
    Preeeus likes this.
  11. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    If they look;).
    My smog place is run by a Prius owner with a visible oil catch can:).
    Depends on who you know like most things(y).
    Grit, m.wynn and mjoo like this.
  12. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Wow..Minnesota doesn't even do inspections or emissions testing anymore...since 1999!
    I'm torn on the value of it. On one hand it is theoretically good for the environment...but on the other hand it adds yet another cost to owning a vehicle ( either in taxes or direct fees ). Plus, cars are in general cleaner these days. However, I'd love it if more 'coal roller' trucks are caught! :whistle:
    With that said..I still haven't installed catch cans. I may just clean the EGR and intake more frequently, etc... As for catch cans, I think my Hyundai Sonata needs one more than the Prius does at this point. (y)
    orenji likes this.
  13. CR94
    CR94 Senior Member
    2,840
    1,246
    Northwestern S.C.
    Pour point is irrelevant, and has not been in the "winter weight" J300 SAE specs for years, because it isn't a valid measure of usability at low temperatures. Better test procedures are in effect nowadays.
  14. capolihu
    capolihu Member
    101
    76
    Mont
    Preeeus, what is the latest? have you started using thicker oil? I heard someone did the piston rings service but the problem came back..
    Preeeus likes this.
  15. Mendel Leisk
    42,383
    ^ Flag him with @Preeeus is more likely to get his attention. I just did, btw. :)
    Preeeus likes this.
  16. capolihu
    capolihu Member
    101
    76
    Mont
    :) thanks. Btw, I'm open for any suggestions.. I read a lot unfortunately though in this topic :(
  17. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I would agree the engine is the same the oils are not, if you have ever had poor oil in or don't know the history of your used car flush it out. I have known a good flushing agent to free up rings and improve oil consumption.
  18. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Are you holding your agent’s name hostage?
    capolihu likes this.
  19. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I have used Motul on my old Prius when I got it. My son has it now plus another 200K miles
  20. capolihu
    capolihu Member
    101
    76
    Mont
    This was not answer to your "good flashing agent's"..
    Grit likes this.
