Excessive oil consumption: Does using thicker oil help?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Jan 9, 2019.
  1. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    It was the answer to what flushing agent I used when I got the car, for flashing I use "black Jack Flashing" but that is on my house roof :)
  2. Preeeus
    Preeeus Member
    258
    60
    Sorry for the delay responding. So many things going on. It's more than a full time job keeping up with personal health and vehicle health! :sick:
    We have not tried thicker oil yet, but are getting very close to trying it. Need to re-read this thread and find the other threads that talk about what the standard oil is for the Prius outside of the USA.
    We've been told by several mechanics that they would never put anything thicker than 5W20 in a Prius. This, of course, gives us pause, as we aren't mechanics and rely heavily on our Prius for long-distance medical appointments.
    Our Prius somehow passed Toyota's oil consumption test. It's very bizarre that the Prius passed, given the well-documented rate at which it consumes oil (we keep a detailed spreadsheet).
    There are only a few possibilities:
    1. Somehow, just during Toyota's oil consumption test, our Prius suddenly and spontaneously consumed less oil.
    2. When Toyota began the test, they overfilled it with oil.
    3. When Toyota began the test, they filled it with the wrong grade of oil.
    4. When Toyota added 1qt of oil at the end of the test, they used an oil pump that wasn't properly calibrated, or accidentally filled it with more than 1 qt.
    The only unique thing about the oil in the Prius during the test was that it was almost due for an oil and oil filter change at the beginning of the test. So the oil and oil filter were a little old. Not sure if that makes a big difference for oil consumption. (Please share your thoughts.)
    Our choices are now to repeat Toyota's oil consumption test, or to give up and either switch to a thicker oil or try adding engine supplements.
    The dealership stated that even with high rates of oil consumption, oxygen sensors and the catalytic converter should not be damaged. They said those were issues with oils many years ago, but is not an issue with modern oils. Hopefully, that is accurate.
  3. orenji
    orenji Senior Member
    5,887
    3,490
    OW-40 Mobil 1, no issues at all.
    Preeeus and Grit like this.
  4. Preeeus
    Preeeus Member
    258
    60
    How many miles you been using that? Change at 5K?
    Thinking about trying Amazon's 5W30 before trying a 40.
    orenji likes this.
  5. orenji
    5,887
    3,490
    30k miles on 0W-40 weight. Change ever 5K miles.
    I was also using 0w-30 prior to 0w-40.
    Preeeus likes this.
  6. Preeeus
    Preeeus Member
    258
    60
    Did you have oil consumption issues using 0W-20 or 5W-20? What about with 0W-30?
  7. orenji
    5,887
    3,490
    I have 108,000 miles and no oil consumption.
    Preeeus likes this.
  8. Preeeus
    Preeeus Member
    258
    60
    Thanks. Why did you switch to 0W-40 if no oil consumption?
  9. orenji
    5,887
    3,490
    I switched because I believe 0W-20 weight is too thin, and only being used to meet CAFE standards. If you look at other countries and Prius manuals they are suggesting the use of thicker oils.
    Preeeus likes this.
  10. Preeeus
    Preeeus Member
    258
    60
    That's what we've heard. Do you have reliable references for standard oils used by Toyota in other countries that use an identical engine and identical oil-related components (pumps/etc.)?
  11. Mendel Leisk
    42,383
    Toyota Aus mentions various oil weights, but still recommends 0W20. Not sure what that proves. Could be partially corporate politics at play?
  12. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Can we say this explanation of yours, about higher viscosity oils, is only applicable to environments with cold temperatures, or you'd still recommend it for Prius in countries with tropical climates?30-45°C?
  13. orenji
    5,887
    3,490
    There have been other threads on Priuschat with post of Toyota manuals reflecting the height weight oils.
  14. orenji
    5,887
    3,490
    Yes as the thicker the oil the better it is for warmer climates.
    Dxta likes this.
  15. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    You could put 80w90 gear lube in the engine. That's pretty thick. Should have any oil blow by.
  16. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    That way just as soon as the odor of the oil wears off, it’s time to change it again. That junk stinks to high heavens. :ROFLMAO::ROFLMAO::ROFLMAO:
  17. ASRDogman
    8,070
    4,092
    Yes it does, it's NASTY! But it works.. :)
  18. Mendel Leisk
    42,383
    Ok, my recollection was off. Here's the 2010 Aus Prius Owner's Manual oil recommendation:
    Preeeus and orenji like this.
  19. Zeppo Shanski
    Zeppo Shanski Active Member
    315
    193
    Chicagoland
    Pennzoil makes a nice thick strait 70 weight oil. My Harley Davidson customers used to grab it up in a flash.
  20. orenji
    5,887
    3,490
    Yes its the 10W that may cause issues in cold weather. So 0W-40 or 0W-30 is no concern for cold weather starting.
    RMB and Mendel Leisk like this.
