Excessive Oil Consumption on 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mark8007, Aug 10, 2016.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    BG Products EPR (also known as PN 109) is an engine flush. You add it to the engine oil prior to an oil change, run the engine at idle for about 10 minutes then drain the oil.
    You can buy it off of Amazon.
    I also add their Extended Life MOA with the fresh oil which keeps the oil basic.
  2. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Okay, thanks!
    I've just drained the oil and filled the crankcase with transmission fluid and let it run.
    It does a great job of cleaning things out.
    But if you use synthetic oil and change when you should, you really shouldn't have a problem.
    I replaced the valve cover gaskets in the town&country at 150,000 and there was a very light film
    on the head. And I could wipe that off with my finger.
    At 374,000, it still looks good!
    But the last change I run transmission fluid in it. When I drained it, it was still a darker red, but not bad.
  3. bentbow
    bentbow Junior Member
    34
    bay area
    374k Miles or km.
  4. ASRDogman
    8,070
    4,092
    Miles, I'm in Florida...
    Only idle, Maybe slight reving. Trans fluid is thin, and you could screw up the bearings if you put a load on them.
    But there are also several engine cleaners to put in the oil before you change it.
    I've use Gunk before, but not sure if they still make it.
  5. bentbow
    34
    bay area
    Holl moly that's a lot of miles. New hv battery, I bet. How is the engine holding up? What year is yours
  6. ASRDogman
    8,070
    4,092
    You missread... My 2002 Chrysler Town and Country has 374,xxx miles. I just turned 141,000 on the 2010 Prius.
    If i had not gotten the Prius July 31, 2017, I'm would have have had 400,000 on the Chrysler....
    #66 ASRDogman, Aug 3, 2018
  7. bentbow
    34
    bay area
    ohhhh, ya i didn't see that part. since we're on priuschat i assumed we were talking about a prius.
  8. ASRDogman
    8,070
    4,092
    Assume? OH NO! You know what that means??? :) :) :)
    But then, I should have been more specific.
    I'm hoping, and should, get the same mileage from the Prius. I really hope I don't drive as much
    as I have in the van. I've driven over a million miles in all my vehicles.
  9. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    I have only heard of ATF added to a crankcase and then run briefly before being drained once before in 1972. The owner claimed that the solvents in the ATF tended to both scavenge accumulations of gunk in the lower crankcase and oil-pan, as well as helping the oil seals on the hydraulic lifters swell up and seal better. The lifters were quieter but that effect was temporary. I would not think that the ATF would affect carbon accumulations in the combustion chambers, but does anyone have real evidence about what the ATF fill, run, and drain really does to an ICE , especially a Prius ICE?
    Raytheeagle likes this.
  10. ASRDogman
    8,070
    4,092
    A Prius engine is the same as any engine. It works the same way.
    Transmission fluid has cleaning properties in it. That's why if you change the fluid in your
    regular auto transmission the insides will always look clean.
    It won't clean everything in an engine. It all depends on how dirty it is, and the oil you used and
    how often you change it.
    With 374,000 plus miles on my van, the valve train still looks clean. I've used Castrol or Mobil 1 synthetic oil.
  11. Longboardluv
    Longboardluv Junior Member
    47
    jeez I just bought a 2010 prius with 50k miles on it and now i'm worried that it's going to start consuming oil!
  12. ASRDogman
    8,070
    4,092
    Pretty much every engine will eventually start burning oil.
    I just turned 160,000 and only use about 1/2-3/4 of a quart every 10,000 miles.
    I am the 2nd owner. The original owner took excellent car of the car, as am I.
    Don't drive it like a Formula 1 car and keep the oil changed, and other maintanence and you'll be fine.
    EVERY car has it's quarks and problems.
    orenji, Raytheeagle and Mendel Leisk like this.
  13. Longboardluv
    47
    thanks for the comforting post, i'm just a little on edge.
  14. ASRDogman
    8,070
    4,092
    Main things is, don't panic! Read over Prius Chat. Lot's of good and bad, mostly good.
    There are always a few that jump the gun and are very negative.
    I also have the 2010. It has been VERY easy to work on!
    When I took on the task of the EGR Cooler cleaning, it looked like it would NOT be fun or easy,
    from the videos. I went step by step from the video, and it was simple. I have some specialty tools that
    made it very easy to get to the two nuts/bolts that everyone seems to have problems with.
    It's a very nice car. Take car of it and it will take car of you! :)
    I like your Bus photo. I had 1966 bus.
    orenji and mjoo like this.
  15. Longboardluv
    47
    awesome will do! nice a fellow VW'er!! check out my youtube channel for our vw antics http://www.youtube.com/vwLifeVW
  16. ASRDogman
    8,070
    4,092
    My first was 63 bug, then the 66 bus, 72 type 3 wagon. My brother had a 73 fastback and my mom a 72 bus, my dad
    a 74(?) type 4. I still have the engine stand to rebuild the motors! And my sister was rebuilding
    a Karmen Ghia. I forget what year though
    #76 ASRDogman, Mar 11, 2019
  17. orenji
    orenji Senior Member
    5,887
    3,490
    I have a 2010 with 106,000 miles great car no oil burning. I would change the oil every 5,000 miles and don’t use 0W-20 weight oil. Depending on your location use 0W-30 or 0W-40 weight oil. I use 0W-40 but I am in California where is not too cold in the winter. Also have the transmission fluid changed out at 60k miles and every 60k miles after. Don’t drive it hard......
  18. boatmana116
    boatmana116 New Member
    North Idaho
    I have a 2010 gen 3 and started to recognize this consumption pattern about 6 months ago. 1qt every 1k miles. IM at 138K.
    Anyone had any luck doing a flush, increasing oil change frequency and type to regain a normal pattern? Vehicle still drives well, just want it to last a 300K. Thanks for any advice.
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    What brand oil & filter do you use?
  20. Jeff Tengesdal
    Jeff Tengesdal New Member
    Appleton WI
    I have a 2010 Prius that started showing a loss of oil (not leaking out the bottom) about a year ago. I've had a consumption test and failed because it didn't burn enough oil in 1200 miles to warrant any action on the part of Toyota. Yet, nowadays, I'm putting in a quart of oil every 2000-2500 miles. Since I'm not adept at auto mechanics or repair, I'd appreciate any advice or recommendations in layperson-speak. Thanks.
