Excessive oil consumption solved by a Ford dealership
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mikeflores2000, Jun 15, 2018.
  1. gliderman
    gliderman Active Member
    751
    225
    Not the EGR. But I cleaned the intake manifold about 100k miles and it looked brand new when I took it apart, and changed the PCV valve too.
  2. padroo
    padroo Senior Member
    2,763
    2,253
    I did my first oil change on my 2016 Prius about three week ago and don't like the plastic cover. I always had a habit of checking the garage floor after an oil change looking for drips. I don't know how much it would have to leak to show up on the garage floor.
  3. Mendel Leisk
    42,349
    There might some sound deadening on the top side of that cover too, might absorb a minor spill.
    On my third gen I remove the entire panel, to avoid stressing that brittle "hinge". Fourth gen it's more tempting though to just take off (completely) that sub-piece at the oil pan. Maybe take the whole panel off anyway, good for leak check, and CV joint look over.
  4. padroo
    2,763
    2,253
    I wish the oil filter was on the front of the engine at least. Next time I will get the car higher in the air for easy access. I have the equipment, I'm lazy.
  5. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    I leave the door open. I change the filter, then drain the oil. While the oil is draining I check the boots by hand, because, as Mendel has stated, you can't see them very well unless you remove the whole undertray, and I'm very lazy! Then refill the oil to "approximately" the correct level (can't tell because the front is so far up - can't even easily reach the dip stick) so I add the "correct" number of litres. Start the engine, check for leaks. Close the door after shutting off the engine. Back the car off the ramps, and then check the oil level and adjust if/as required. My ramps lift the front of the car about 18" off the ground. I have to use a wheel "chock" to make sure it stays up there. ;)
  6. Mendel Leisk
    42,349
    David, what I do, is let it drain good, torque the drain bolt and filter, underpanel back on, car back on the floor (I do the lift with a floor jack and safety stands) and then just add the spec'd. quantity, dub it done. I'll take a cursory look at the dipstick, just to make sure it's registering.
    I will check the level more carefully a day or two later, after some driving. So far it's always been right at the top mark, or ever so slightly low, by this method.
    #26 Mendel Leisk, Jun 16, 2018
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    My method- tighten the filter with filter cap til I can't tighten anymore, it actually stops/bottoms out safely. Tighten drain bolt and stop when I see the washer slowly physically bend or lightly crushed.
  8. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    My little metal tab is sitting in the drawer of my toolbox. It just seemed to get in the way of my oil filter wrench, and then when I got the wrench on it would still be trying to prevent the filter from loosening. Total pain in the butt.
  9. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    I wished they would put the filter on top like BMW does. That would be extremely easy!
    Merkey likes this.
  10. padroo
    2,763
    2,253
    If they made it easy everyone would change their own oil. :p
    Raytheeagle and frodoz737 like this.
  11. ASRDogman
    8,066
    4,089
    I know! What a nightmare that would be! :)
  12. mikeflores2000
    mikeflores2000 Junior Member
    52
    23
    Merced, CA
    No, more likely oil leaked underneath oil filter out of sight and onto roadway during cruise. Stevens Creek Toyota in San Jose, CA
    denied any leaks despite ordering an inspection but they went ahead and comped me for an oil change next time.
  13. mikeflores2000
    52
    23
    Merced, CA
    Toothless yes, but give a heads up to buy or pass on these problem vehicles.
  14. mikeflores2000
    52
    23
    Merced, CA
    Point granted however leaking and consuming not known until root cause found. In my case the leak went unnoticed and putting in oil to replenish was perceived as consuming oil. Hindsight is consuming oil means burning oil with clouds of smoke which is not the case.
    So yes, point granted could have titled Excessive leaking of oil.
