Excessive Oil: *PLEASE* do report! Instructions from Toyota here
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Jan 29, 2019.
  1. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
    If you do a Berryman B-12 Piston Soak Procedure it could potentially help cure your oil consumption.
    Berryman B-12 is basically straight solvent and will completely obliterate any carbon clogging the rings and oil return passages. Could probably be comparable to lacquer thinner somewhat.
    It has cured my oil consumption in my Gen 2 Prius from a quart every 1,000-2,000 miles down to a negligible amount.
  2. Mendel Leisk
    42,324
    From the Safety Data Sheet:
    link
    TheLastMojojomo likes this.
