Excessive Wheel Spin
Discussion in 'Prime Main Forum (2017-2022)' started by m8547, Jan 10, 2019.
  1. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Your Prime has way too much power, it's time to get a slower car....
    On a serious note, deflate your Blizzaks down to ~28 to 30 psi; this should solve your problem most of the time.
    Rob43
  2. juhjuhjuhjames
    juhjuhjuhjames Junior Member
    49
    seattle
    Yeah, naturally I just drive slower in the Prius, but I’m in Seattle so there was a good chance the roads were slick when I heard the “clunk” noise maybe that was it?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And ALL cars do that.
    It is just way more noticeable on ones with:
    Not much weight.
    Narrow LRR tires.
    Front wheel drive.
    Torquey electric motors.
    In addition to person-hole covers, the painted stripes on the roads tend to be slick even when dry.
    The wide white "stopping lines" often are the worst.
  4. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    That would probably help. My car was delivered with something like 55 PSI in all four tires. It was like driving on ice until I realized I should check the pressure. I usually run about 35 in the blizzaks and 38-ish in the all seasons.
  5. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    At 55 psi you could drive over a dime and tell if it’s heads or tails.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    If you think the one wheel slip on manhole covers, gravel, paint, (and don't forget tar snakes!!) is bad in a Prius, try it on a motorcycle. :eek:
    Just drive it.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    Actually that is really good training.
    As long as another vehicle isn't tailgating you at the time. (y)
    jerrymildred likes this.
