Exclamation Mark with a car behind it, help please..
Discussion in 'Prius v Main Forum' started by DavidDavid, Mar 22, 2023.
  1. DavidDavid
    DavidDavid Junior Member
    29
    Can you help with this please, what is the bottom warning light means?
    I am working on 2014 Toyota Prius V 214K miles, it's the only light I am getting, no other warning light, I have a good scanner, do I need to scan the hybrid system or other systems?
    Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,027
    6,916
    Texas Hill Country
    Hybrid System Warning light. Yes you need a hybrid compatible code reader.
  3. DavidDavid
    29
    Thank you, I have a good scanner, I will have it scanned tomorrow
  4. ChapmanF
    18,969
    Or, you have a scanner, you will have it scanned tomorrow, and that's when we'll know if it's a good scanner or not. :)
    Some of them won't show you the codes behind Prius hybrid system warnings.
  5. DavidDavid
    29
    The code is P0AA6 the sub codes are 526 614, I am getting code for the AC system which not working B1498, the engine has been changed lately.
  6. rjparker
    11,027
    6,916
    Texas Hill Country
    High voltage isolation code sometimes the hv battery if unskilled hands have been in there, the inverter, cabling or reportedly the ac connector.
    Tim Jones likes this.
  7. DavidDavid
    29
    Thank you, the vehicle starts and runs fine, the only issue is AC system, fans are not coming on neither the AC compressor, I think I am going to try to fix the AC system first and see if it will fix both issues.
  8. ChapmanF
    18,969
    This picture is for a Gen 2; Gen 3 is mostly the same. The 614 area is the "high-voltage DC area", which includes possibilities from a few of the components on the load side of the battery relays, through the frame wire to the front of the car, and most of what's in the inverter box, except for the smidgen that falls in the 613 transaxle area.
    The one important change from Gen 2 to Gen 3 for this has to do with how the A/C is powered. Gen 2 had an A/C inverter inside the inverter box, sending three-phase AC to the A/C compressor. (I wish I could write that sentence without so many ACs and A/Cs in it.)
    In Gen 3, high-voltage DC goes to the compressor, and the inverter that makes the AC to turn it is inside the compressor itself. Because of that, in Gen 3, the 614 high voltage DC area also includes the orange wires from the inverter to the compressor, and a portion of the compressor itself, and the 611 A/C area shrinks to only be inside the compressor itself.
    So looking into the power-to-the-compressor issue here really might be the right call for this set of codes.
    DavidDavid likes this.
  9. DavidDavid
    29
    Very interesting information, thank you so much, I am going to start with the AC 40A fuse, is there a special way to test it?
  10. ChapmanF
    18,969
    If you can scare up a copy of the P0AA6-614 troubleshooting instructions for Gen 3, they'll suggest a good sequence and procedure for testing.
  11. rjparker
    11,027
    6,916
    Texas Hill Country
    It is not about fuses, it is literally high voltage leakage to chassis. The hv dc is isolated from chassis on plus and minus except in your car. At least when the code was set. Have you tried clearing codes?
  12. DavidDavid
    29
    I cleared it several times, it comes back right away, except one time it came when I turned the AC, that’s why I think it may have something to do with AC system, the vehicle runs fine, the voltage of all hybrid cells look fine.
  13. ChapmanF
    18,969
    A lot of people with these isolation codes talk about looking at battery block voltages. Battery block voltages are of interest for other sorts of problems. An isolation fault isn't about those.
  14. DavidDavid
    29
    I worked on today, here is new thing I have found, every time I start the vehicle the AC code comes up right away the B1498, and about a 30 seconds later the hybrid code comes up the P0AA6, now when I unplugged the the AC compressor, the high voltage and the black harness at the top, only the AC code comes up but the hybrid code, I am thinking there a short in the AC compressor, what do you think.
  15. ChapmanF
    18,969
    Sounds like a reasonable inference.
  16. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Could be the plug that goes into the Compressor...... Gently pull the glug off and inspect it and the Compressor Pins....
    Look VERY Cafefully..... Close
    Water can also get in there and ruin the connection.... have to have a new compressor if that happens
  17. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
