Exclamation point and problem on 2007 prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sharonna, Feb 15, 2018.
  1. Sharonna
    Sharonna New Member
    San Diego
    I had exclamation point in a triangle and problem on a screen few days ago. Read on prius chat that its low oil. Next day the oil was changed. After oil change next day (yesterday) no lights came up. Today the same lights again. Can someone help me and could explain me whats going on?
  2. JC91006
    16,933
    8,643
    The red triangle does not mean the car is just low on oil, it's telling you there's a problem with the car.
    I suspect you have a bad inverter pump. That usually causes intermittent triangle to appear. You can verify this by reading the codes on the car
    SFO and Raytheeagle like this.
  3. Sharonna
    Sharonna New Member
    San Diego
    There was and oil light on a screen as well in a top left corner.
  4. JC91006
    16,933
    8,643
    There are probably more lights on? Anything else you're leaving out?
    If you read the codes, you'll know your problem without guessing
    edthefox5 and Raytheeagle like this.
  5. Sharonna
    Sharonna New Member
    San Diego
    There is no other lights...
    I don't really know about cars. Where can i read these codes?
    Thank you
  6. JC91006
    16,933
    8,643
    If there are no other lights, you most likely have 2 issues.
    Low coolant or failed inverter pump.
    You should not drive long distances until you find out the issue (less than 10 miles)
  7. Sharonna
    Sharonna New Member
    San Diego
    Thank you so much.
    How can I find out, without going to mechanic? If its low coolant?
  8. JC91006
    16,933
    8,643
    I would first check the inverter coolant reservoir first, turn the car on READY, then see if the inverter coolant has movement in the coolant. If the car is Ready and no movement in the coolant, the inverter pump is not working. If there is movement, then proceed to next step, which is checking engine coolant level at the radiator
  9. JC91006
    16,933
    8,643
    Raytheeagle and SFO like this.
  10. Sharonna
    Sharonna New Member
    San Diego
    I've checked this reservoir, and it was empty. Can I just poor a water?
  11. JC91006
    16,933
    8,643
    No, you need to have PINK Asian fluid in there. Either from a Toyota dealer or an autoparts store.
    The question now is how the heck did that get empty? That's not suppose to empty on it's own.
  12. Sharonna
    Sharonna New Member
    San Diego
    I don't actually know ....
  13. JC91006
    16,933
    8,643
    The coolant at the dealer runs about $25-$30 a gallon, less expensive versions are at autoparts stores for under $20.
    But you really don't want to fill it and have it leak out again. It's not cheap fluid....but on the other hand, it costs $120 for a dealer to just diagnose the problem.
  14. padroo
    padroo Senior Member
    2,763
    2,253
    Have you noticed anything dripping under your car? I would recommend you find someone who knows cars to check all the fluids in your car. The cooling take the same coolant as was mentioned above, they are both pink.
  15. padroo
    2,763
    2,253
  16. JohnLS
    JohnLS Junior Member
    Don't use water and don't use standard antifreeze. Some helpful discussions if you Google "Prius inverter coolant"
    LG-H830 ?
  17. Sharonna
    Sharonna New Member
    San Diego
    I had to go to see a mechanic today cause check engine light came up. They ran a diagnostic, and there was a p0012 code...
  18. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Besides the thrown code (P00012), what else did the mechanic say or do?
    Length of ownership and total miles on this prius?
    Who generally services the prius and where at?
    Raytheeagle and padroo like this.
  19. padroo
    2,763
    2,253
  20. Sharonna
    Sharonna New Member
    San Diego
    Oil has been changed few days ago.
