Exclamation point and problem on 2007 prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sharonna, Feb 15, 2018.
  1. Sharonna
    Sharonna New Member
    San Diego
    The mechanic deleted the code, and told drive. If the code comes up again , so that part must be changed. I don't remember the name.
    I own this car only 6 months. The previous owner used to take care of this car, he has a body shop.
    It is 2007 Toyota prius and mileage is 137k
    52,763
    probably took a rock to your radiator.
  3. Sharonna
    Sharonna New Member
    San Diego
    But radiator is not leaking. I was told that camshaft solenoid adjuster must be changwc.
    52,763
    really? wow, that's crazy! where did the coolant go?
  5. Sharonna
    Sharonna New Member
    San Diego
    I don't really know
  6. bisco
    52,763
    that's why i would refill it, and watch the level. deal with the camshaft flux capacitor later.
    edthefox5 and Raytheeagle like this.
  7. Patrick Wong
    18,210
    6,517
    What was your mechanic's evaluation of this issue?
  8. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Did you pay for a CarFax report? Did you pay an independent shop or someone who is far more automobile savy, assess the car prior to your purchase?
    I would not be surprised if this car is salvaged. Previous owner has a body shop. Definitely has the means to turn a wreck into someone else's problem.
    edthefox5 likes this.
  9. Sharonna
    Sharonna New Member
    San Diego
    Another question: after I'VE seen a mechanic, and scanner showed this p0012 code, they deleted this code. I'm still driving as it is. The lights doesn't show up anymore. But I can feel, that car lost it's power while driving up the hill, used to drive at least 65mph, now its 50mph, and engine sounds like having difficult time going faster when imI giving gas. Nothing was done to the car, I haven't replaced any parts yet. My mechanic asked me to drive as it is, and just wait if the same lighs shows up again.
    Yesterday i checked under the car, and could see that something is dripping - car was parked at least for 6-7 hours. Could that be from coolant reservoir, or from AC?
  10. JC91006
    16,933
    8,643
    If it's pink, it's coolant. If it's clear, it's probably from the ac. You can wipe up a little with a white napkin and check
    Sharonna likes this.
  11. Sharonna
    Sharonna New Member
    San Diego
    I think it's leaking from transmission. Every day I can see there is a dripping under my car. Looked under the car, I can see drop of oil on a transmission. Can I temporary add some oil, while I'm gonna sort out what to do next?? Extremely unlucky with this car. Prius is 2007, with 137k.
  12. Sharonna
    Sharonna New Member
    San Diego
    No, it is brownish i would say
  13. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Brownish sounds oil'ish.
    Did you touch or feel for viscosity?
    Transmissions generally use 'fluid', though it can be equally argued otherwise.
    If you have a basic interest in maintaining or servicing this vehicle, you can download a manual from :
    Toyota Online Owners Manuals and Warranty
    Raytheeagle likes this.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Please find a hybrid car service and take your car to them asap before you blow it up.
    Driving while leaking engine oil trans fluid engine coolant inverter coolant window washer fluid brake fluid take your pick will be very costly in the long run while you try to fix your car via the internet.
    jerrymildred likes this.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I'm with Ed on this. You said you don't know much about cars and this is clearly way beyond something you can deal with yourself. It needs a Prius mechanic asap or you'll destroy the car.
